Quantcast 1991 f250 witha 5.0 - Ford Truck Club Forum
Old August 21st, 2015, 03:51 PM
skinny116's Avatar
skinny116 skinny116 is offline
Default 1991 f250 witha 5.0
my f250 with a 5.0 is a 91 model,
it's idling ruff, 1/2 the horsepower, black smoke coming out of tail pipe.
I replaced plugs, wires, #1 injector, idle air control valve, distributor cap, and rotor button, ignition module.. cant figure it out. replaced plenum gasket, but cant find any vacume leaks on top of motor..
can anyone tell me, what's wrong with my truck..
thks
Old August 21st, 2015, 03:53 PM
skinny116's Avatar
oh and I replaced fuel twice. thought I might have bought a bad one..
when it starts from cold start.. runs great. about a minute or two later... starts rough idle,
then, it's like almost a bad skip...
Old August 21st, 2015, 06:18 PM
Images: 624
Liked 185 Times in 167 Posts
have you pulled the codes
I think your year is done with a paper clip and a light flashing the code
Old August 22nd, 2015, 01:01 AM
Liked 99 Times in 96 Posts
Probably the O2 sensor. Reason it runs great for the first couple minutes is it's still in open loop and the O2 sensor is ignored.
Old August 22nd, 2015, 08:16 AM
Images: 624
^^^ that makes good sense; O2 sensor in open loop; something I would have never known
all these electronic gadgets on engines now days has me baffled
and I have to turn to someone else
Old August 22nd, 2015, 08:26 AM
Images: 624
see this for pulling your codes
http://www.fordtruckclub.net/forum/s...ead.php?t=6720
Old August 22nd, 2015, 08:32 AM
Images: 624
also look up Six Liter Tune Up
don't let the six liter confuse you,
six liter is the screen name of the guy who came up with it
I did a search but came up empty
it's in here somewhere
Old August 24th, 2015, 08:17 AM
my 91 5.0 is equipped with a a vapor canister purge solenoid on the side of the throttle body. the previous owner of the vehicle must have changed it because it was plumbed backwards. truck ran good at first,....after it got warm it idle real rough. turned it around the right way,...truck ran like a dream. just a thought.
50ford67 , Fuelman , glc , harrison28 , JSoko , quickcraze , skinny116
1991 Silver Anniversary Edition BigRob 1987-1991 Ford Bronco
14 April 19th, 2016 07:20 AM
1991 F150 4X4 Hub/Rotor Availability? RetTech 1973-1991 Ford F150
13 December 21st, 2012 05:40 PM
1991 f150 5.0 efi DON CHILDS 1973-1991 Ford F150
12 October 10th, 2012 03:44 PM
1991 4.0 code 85 Klitch 1989-1992 Ford Ranger
0 March 20th, 2012 11:52 PM
1991 , f250 , witha
