Quantcast 1997 F250 light duty - rear window separated from track - Ford Truck Club Forum
Old January 18th, 2017, 12:35 AM
MADV79's Avatar
MADV79 MADV79 is offline
Default 1997 F250 light duty - rear window separated from track
Have any of you experienced a rear window that is separating from mounding? The rear sliding window on my truck is off the track and about a half inch away from the frame. Not sure what I should do, but it leaks.
Old January 29th, 2017, 08:30 PM
Images: 243
Liked 34 Times in 33 Posts
show us a picture
Old April 26th, 2017, 04:00 PM
OffRoadBum's Avatar
OffRoadBum OffRoadBum is offline
i bet your body mount has collapsed, it is common on these trucks. check the body lines on the side where the seal is giving you trouble.
Old April 27th, 2017, 10:28 AM
glc glc is online now
Liked 99 Times in 96 Posts
You do realize the 1997 and 1998 F250 "light duty" is really a 97-03 F150 body, not the same body as yours?
Old April 28th, 2017, 08:40 AM
OffRoadBum's Avatar
i do! it common on both. on yours due to rust and fatigue, 3 out 5 of the 98-99 we owned did it. those trucks we got from a lease company up north, the rust from the cab corners cause fatigue to weaken the area around the mount causing the cab to sag. now those trucks also showed me that ford needed to rethink their corrosion control engineering on that generation. they were a nightmare on maintenance because of it.
glc , harrison28 , JSoko , MADV79 , OffRoadBum , skatebowd
Rear Window Shattered Ford F-150 jncrowe12 2009-2014 Ford F150
1 June 25th, 2016 08:53 AM
Buying a 1997 f250 for parts?? labrat 1999-2007 Ford F250 | F350
2 February 26th, 2015 09:15 PM
Trim on edges of sliding glass in rear window? F150GT 1992-1996 Ford F150
0 December 13th, 2013 12:29 PM
Rear Window TwoSpeed 1992-1996 Ford F150
23 June 7th, 2013 04:23 PM
1996 Bronco with rear window issues... LOBO2 1992-1996 Ford Bronco
5 August 23rd, 2012 12:37 PM
1997 , duty , f250 , light , rear , separated , track , window
