Quantcast 1998 E-150 Conversion Van for towing - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford Vans
Old September 13th, 2017, 02:38 PM
moshe1436's Avatar
moshe1436 moshe1436 is offline
Default 1998 E-150 Conversion Van for towing
This '98 Ford E-150 seems to be rated to handle a CGRW of 13,000 lbs. To do this the vehicle should have a tow-package and an auto tranny. My van has a 5.4 c.i. V-8. I'm sure it has a tranny cooler but beyond that I don't know exactly what a tow package consists of. The sticker on the left column says it's rated at GVWR of 7,000 lbs, as well as having axle "19" which I believe is a 3.55:1 axle. The following four codes on the sticker I don't understand: BRK - C; R - 8; TR - E; SPR- ZC/ULM. I have not purchased the trailer yet but would like to buy a 2013 Keystone Hideout 26RLS. The GRWR of the trailer is 7,850 lbs. I am concerned about overloading the van suspension and the class III hitch that I have even though I'll be using a load equalizing hitch and sway bar system. Any help regarding the four codes mentioned above will be appreciated as well as any opinions on my towing questions. Many thanks.
Old September 13th, 2017, 07:39 PM
7850 is too much for any 1/2 ton van, sorry. Find something lighter.
The only thing that really tells me is you have a E4OD transmission, which is a good thing.
Old September 14th, 2017, 09:21 AM
moshe1436's Avatar
Thank you for your response. Disappointing, and I have canceled my purchase of the trailer and will now be looking for something lighter. I guess the logical question, based on the info in my original post, is to ask what would be the maximum trailer weight that I could tow. I would think one of the "Light"/"Lite" trailers might be an option but again I need to know what the club feels would be the maximum towing weight. Thanks.
Old September 14th, 2017, 10:19 AM
I'd limit it to 6k. I'd also put load range E tires on it. The stock tires are marginal for a conversion van even before adding any kind of load.
Old September 14th, 2017, 12:51 PM
moshe1436's Avatar
Thanks glc! Appreciate your opinion. The "load range E" tires are an excellent recommendation. Is your 6,000 lbs limit is the "dry weight" of the trailer or GCWR of the trailer and contents? I would assume you mean the "dry" or "unladen weight. I don't " of the trailer. Please clarify! Many thanks for your input!
Old September 14th, 2017, 09:01 PM
Your official max tow rating is in the 6500 to 6900 pound range with a standard E-150 van or wagon. The conversion will lower that, so that's why I say 6k max, and that's fully loaded. This does require a towing package, which has an upgraded transmission cooler and a factory installed Class 3 hitch.
Old September 15th, 2017, 08:31 PM
moshe1436's Avatar
Thanks for the info. It's all been very helpful. I'm not buying the heavier unit that I wanted and your information has been valuable.
Old September 21st, 2017, 07:18 AM
good info given here
the first thing that will suffer will be the transmission, with any tow
Old September 21st, 2017, 09:01 AM
moshe1436's Avatar
Yes, I suspect you're correct with a possible tranny failure. The use will include no hills (we live in Florida) and short trips to local State Parks. But I hear what you're saying. In response to others with good suggestions: I bought a camper 2000 lbs lighter than the original one I was going to buy and feel this will be a good fit with the van. Thanks to all with all your responses.
Old December 5th, 2017, 09:40 PM
moshe1436's Avatar
I want to install a Transmission Temperature Gauge on my '98 Ford Conv. Van that has an E40D transmission. Any suggestions as to which one would be a good match? Thanks!
79GreenishF100 , glc , harrison28 , JSoko , moshe1436
towing {(heavy towing) whats the max} michaelsnodgrass18 1992-1996 Ford F150
13 May 4th, 2013 01:32 AM
1998 f150 will not start! Less than 70k!!! Help me! justinTriton 1997-2003 Ford F150
8 January 20th, 2013 09:33 PM
Hello everybody! 1998 F150xlt justinTriton New Member Introductions 5 July 15th, 2012 01:07 AM
1998 Expedition Codes NEED HELP! eddog1345 Ford Expedition 2 January 1st, 2012 10:59 AM
Ranger: 1998-99 recalls BigT67 1998-2000 Ford Ranger
0 July 5th, 2009 06:35 PM
1998 , conversion , e150 , towing , van
