Quantcast Ranger: 1998-99 recalls - Ford Truck Club Forum
Ford Truck Club Forum > RANGER | MAZDA-B > 1998-2000 Ford Ranger
Old July 5th, 2009, 06:35 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
Exclamation Ranger: 1998-99 recalls
NHTSA Recall Campaign Number: 06E056000
Component: FUEL SYSTEM, GASOLINE
Details: CERTAIN AFTERMARKET FUEL FILTERS SOLD UNDER THE PUROLATOR BRAND NAME, P/N F65277, SHIPPED FROM JANUARY 16 THROUGH JUNE 2, 2006, FOR USE ON THE ABOVE LISTED PASSENGER VEHICLES. DUE TO INCORRECT DESIGN, THE QUICK CONNECTORS MAY NOT FULLY SEAT WITH THE TUBE INTERFACE, EVEN THOUGH THE PERSON MAKING THE CONNECTION MAY BELIEVE THAT THE QUICK CONNECTOR IS FULLY ATTACHED.
Consequence: FAILURE OF THIS CONNECTION COULD LEAD TO FUEL SPILLAGE AND, IN THE PRESENCE OF AN IGNITION SOURCE, A FIRE COULD OCCUR.
Corrective Action: UFI WILL NOTIFY OWNERS AND REPLACE THE FILTERS FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 4, 2006. OWNERS MAY CONTACT UFI FILTERS USA AT 800-230-5876.
Units Potentially Affected: 58640
Recall Initiated By: MFR
Date added to NHTSA datbase: 06/23/2006
NHTSA Recall Campaign Number: 97V186001
Component: FUEL SYSTEM, GASOLINEELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Details: VEHICLE DESCRIPTION: LIGHT DUTY PICKUP TRUCKS EQUIPPED WITH 4.0L ENGINES. THE FLEXIBLE SECTION OF THE CHASSIS MOUNTED FUEL LINE THAT CONNECTS TO THE ENGINE WAS ROUTED TOO CLOSE TO THE EXHAUST MANIFOLD. THE LINE COULD CONTACT THE MANIFOLD.
Consequence: THIS COULD POTENTIALLY RESULT IN DAMAGE TO THE FUEL LINE, OR IN SOME CASES, CAUSE A FUEL LEAK. FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.
Corrective Action: DEALERS WILL INSTALL AN ADDITIONAL CLIP TO HOLD THE FUEL LINE IN THE INTENDED DESIGN POSITION.
Units Potentially Affected: 2000
Date added to NHTSA datbase: 11/25/1997
NHTSA Recall Campaign Number: 09E025000
Component: EXTERIOR LIGHTING:HEADLIGHTS
Details: DOPE, INC. IS RECALLING 42,540 COMBINATION CORNER AND BUMPER LAMP ASSEMBLIES OF VARIOUS PART NUMBERS SOLD FOR USE AS AFTERMARKET EQUIPMENT FOR VARIOUS PASSENGER VEHICLES. THESE HEADLAMPS FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THESE LAMPS DO NOT CONTAIN THE REQUIRED AMBER SIDE REFLECTORS.
Consequence: DECREASED LIGHTING VISIBILITY MAY RESULT IN A VEHICLE CRASH.
Corrective Action: DOPE, INC. WILL NOTIFY OWNERS AND OFFER A FULL REFUND FOR THE NONCOMPLIANT COMBINATION LAMPS. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING MAY/JUNE 2009. OWNERS MAY CONTACT DOPE, INC. AT 1-626-272-1798.
Units Potentially Affected: 42540
Recall Initiated By: OVSC
Date added to NHTSA datbase: 05/11/2009
NHTSA Recall Campaign Number: 06E026000
Details: CERTAIN PRO-A MOTORS CORNER LAMPS, TURN SIGNALS, AND HEADLIGHTS SOLD AS REPLACEMENT LAMPS FOR USE ON CERTAIN PASSENGER VEHICLES LISTED ABOVE. SOME COMBINATION LAMPS THAT ARE NOT EQUIPPED WITH AMBER SIDE REFLECTORS FAIL TO CONFORM TO FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.
Consequence: WITHOUT THE AMBER REFLECTORS, THE VEHICLE WILL BE POORLY ILLUMINATED, POSSIBLY RESULTING IN A VEHICLE CRASH WITHOUT WARNING.
Corrective Action: PRO-A MOTORS WILL NOTIFY OWNERS AND OFFER TO REPURCHASE THE LAMPS. THE RECALL BEGAN ON APRIL 3, 2006. OWNERS MAY CONTACT PRO-A MOTORS AT 323-838-2988.
Units Potentially Affected: 61944
Date added to NHTSA datbase: 03/23/2006
NHTSA Recall Campaign Number: 09E012000
Details: SABERSPORT IS RECALLING 16,270 COMBINATION CORNER AND BUMPER LAMP ASSEMBLIES OF VARIOUS PART NUMBERS SOLD FOR USE AS AFTERMARKET EQUIPMENT FOR VARIOUS PASSENGER VEHICLES. THESE HEADLAMPS FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THESE LAMPS DO NOT CONTAIN THE REQUIRED AMBER SIDE REFLECTORS.
Corrective Action: SABERSPORT WILL NOTIFY OWNERS AND OFFER A FULL REFUND FOR THE NONCOMPLIANT COMBINATION LAMPS. THE SAFETY RECALL BEGAN ON MAY 11, 2009. OWNERS MAY CONTACT SABERSPORT AT 1-909-598-7589.
Units Potentially Affected: 16270
Date added to NHTSA datbase: 04/07/2009
NHTSA Recall Campaign Number: 07V336000
Component: VEHICLE SPEED CONTROL
Details: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND THEN OVERHEAT, SMOKE, OR BURN.
Consequence: THIS COULD RESULT IN AN UNDERHOOD FIRE.
Corrective Action: DEALERS WILL INSTALL A FUSED WIRING HARNESS. OWNERS OF THE PASSENGER CARS INCLUDED IN THIS CAMPAIGN WILL BE INSTRUCTED TO RETURN THEIR VEHICLES TO THEIR DEALERS TO HAVE THE SPEED CONTROL DEACTIVATION SWITCH DISCONNECTED AS AN INTERIM REPAIR. AS SOON AS REPAIR PARTS ARE AVAILABLE (EXPECTED OCTOBER 2007), OWNERS WILL BE INSTRUCTED TO RETURN TO THE DEALERS FOR INSTALLATION OF A FUSED WIRING HARNESS. THE RECALL BEGAN ON AUGUST 13, 2007, AND MAILING COMPLETED BY SEPTEMBER 19, 2007. OWNERS MAY CONTACT FORD AT 1-888-222-2751.
Units Potentially Affected: 3600000
Recall Initiated By: ODI
Date added to NHTSA datbase: 08/03/2007
NHTSA Recall Campaign Number: 99V062001
Details: VEHICLE DESCRIPTION: CERTAIN 1997-1999 RHD EXPLORER EQUIPPED WITH 4.0L OHV/SOHC ENGINES AND CRUISE CONTROL BUILT FROM MAY 29, 1996 THROUGH MARCH 4, 1999; 1998-1999 EXPLORER/MOUNTAINEERS EQUIPPED WITH 4.0L OHV/SOHC OR 5.0L ENGINES OR 1998-1999 RANGERS EQUIPPED WITH 2.5L, 3.0L FFV/EFI OR 4.0L ENGINES AND CRUISE CONTROL BUILT FROM JANUARY 5, 1998 THROUGH MARCH 4, 1999; 1998-1999 MUSTANGS EQUIPPED WITH 3.8L, 4.6L 2-VALVE OR 4-VALVE ENGINES AND CRUISE CONTROL BUILT FROM MARCH 2, 1998 THROUGH MARCH 4, 1999; 1999 F250/F350/F450/F550 (OVER 8,500 LBS.) TRUCKS EQUIPPED WITH 5.4L OR 6.8L ENGINES AND CRUISE CONTROL BUILT FROM MARCH 2, 1998 THROUGH MARCH 4, 1999; AND 1999 F-53 STRIPPED CHASSIS EQUIPPED WITH 5.4L OR 6.8L ENGINES AND CRUISE CONTROL BUILT FROM MARCH 2, 1998 THROUGH MARCH 4, 1999. A CRUISE CONTROL CABLE CAN INTERFERE WITH THE SPEED CONTROL SERVO PULLEY AND NOT ALLOW THE THROTTLE TO RETURN TO IDLE WHEN DISENGAGING THE CRUISE CONTROL.
Consequence: IF THE CRUISE CONTROL IS USED AND THIS CONDITION IS PRESENT, A STUCK THROTTLE COULD RESULT, WHICH COULD POTENTIALLY RESULT IN A CRASH.
Corrective Action: DEALERS WILL REPLACE THE CRUISE CONTROL CABLES. AT THE PRESENT TIME, THE REPLACEMENT CABLES ARE NOT AVAILABLE. CUSTOMERS ARE BEING ADVISED NOT TO USE THE CRUISE CONTROL SYSTEM UNTIL A REPLACEMENT CAN BE MADE. Replacement cables are available. Contact your local dealer for info.
Units Potentially Affected: 898739
Date added to NHTSA datbase: 03/31/1999
NHTSA Recall Campaign Number: 98V021000
Component: EQUIPMENT:OTHER:LABELS
Details: VEHICLE DESCRIPTION: LIGHT DUTY FOUR-WHEEL DRIVE PICKUP TRUCKS EQUIPPED WITH OFF-ROAD OPTION. THE TIRE AND RIM IDENTIFICATION INFORMATION IS INCORRECT ON THESE VEHICLES. THIS DOES NOT COMPLY WITH THE REQUIREMENTS OF FMVSS NO. 120, "TIRE SELECTION AND RIMS FOR MOTOR VEHICLES OTHER THAN PASSENGER CARS."
Consequence: THE 16" TIRES COULD NOT BE INFLATED ON THE SPECIFIED 15X7.0J RIM.
Corrective Action: OWNERS WILL BE SENT A SAFETY CERTIFICAITON LABEL PARTIAL OVERLAY WHICH WILL CONTAIN THE CORRECT RIM SIZE, AND INSTRUCTIONS FOR AFFIXING THIS LABEL TO THE VEHICLE. IF AN OWNER SO DESIRES, THEIR FORD DEALER CAN INSTALL THE LABEL FOR THEM.
Units Potentially Affected: 11500
Date added to NHTSA datbase: 02/10/1998
NHTSA Recall Campaign Number: 99V204000
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Details: VEHICLE DESCRIPTION: ELECTRIC VEHICLES. THE TRANSAXLE MAY HAVE BEEN MANUFACTURED WITH THE PARK DETENT SPRING MISALIGNED. IF THE SPRING IS MISALIGNED, THE PARK MECHANISM MAY NOT ENGAGE WHEN THE SHIFT LEVER IS PLACED IN THE PARK POSITION.
Consequence: IF THE PARK MECHANISM DOES NOT ENGAGE AND THE VEHICLE OPERATOR HAS NOT APPLIED THE PARKING BRAKE, THE VEHICLE COULD ROLL FREE AS IF IN NEUTRAL.
Corrective Action: DEALERS WILL INSPECT THE TRANSAXLE AND ANY WITH MISALIGNED PARK DETENT SPRINGS WILL BE REPLACED.
Units Potentially Affected: 326
Date added to NHTSA datbase: 07/29/1999
Big T
« There is no previous thread | Kick-Ass Rangers »
CharlieM , cowguy , DoubleDee , fbm1344t , Guest , Mongolink
Chrysler recalls more than 25,000 vehicles BigT67 General Discussion
0 June 5th, 2010 12:27 AM
1998 F150 Coolant Change DIXIE FIX Garage Talk: Shop Class 101 13 April 16th, 2010 05:34 PM
1998 NASCAR Special Edition Sp. Ed. F-150 info and Q&A 98nascartruck More Special Edition F150's
7 August 28th, 2009 12:22 AM
1998 NASCAR Special Edition Sp. Ed. F-150 98nascartruck More Special Edition F150's
0 July 16th, 2009 10:15 AM
Ford ESCAPE Recalls BigT67 General Discussion
0 July 2nd, 2009 02:18 PM
ranger , recalls
