Quantcast How to Change the EGR on a 2000 Ford F-150 - Ford Truck Club Forum
Old July 15th, 2011, 09:33 AM
Images: 624
Liked 185 Times in 167 Posts
Lightbulb How to Change the EGR on a 2000 Ford F-150
Change the EGR on a 2000 Ford F-150 The Exhaust Gas Recirculation (EGR) Valve on the 2000 Ford F-150 is located on the back of the intake manifold, just in front of the firewall. Occasionally, the EGR valve can get clogged, causing the engine to operate inefficiently. Replacing the EGR valve can be done with just a few common tools and you can save time and money by doing the work yourself.
Things You'll Need
Open-end wrench
Crescent wrench
Socket wrench set
1
Unfasten the negative battery cable of the 2000 Ford F-150 from the battery post with an open-end wrench. Locate your EGR valve on the back of the intake manifold underneath the carburetor.
2
Remove the rubber vacuum hose from the metal port at the top of the valve by hand. Unfasten the emissions tube from the bottom of the EGR valve by loosening the nut with a crescent wrench and pull the tube away from the valve carefully.
3
Loosen the bolts that secure the EGR valve to the intake manifold with a socket wrench and take the valve off the motor.
4
Attach the new EGR valve to the motor with bolts and fasten the emissions tube to the bottom of the valve with the crescent wrench.
5
Connect the rubber vacuum hose to the metal port at the top of the new EGR valve and reattach the negative battery cable to the battery post of the 2000 Ford F-150.
ASwaff400 , JSoko
How to Change the PVC Valve on a 1984 Ford F-150 JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:27 AM
2000 f150 3rd member * Terry G. 1997-2003 Ford F150
7 June 16th, 2011 08:55 AM
2000 F150 Windshield wiper problem hvykvy951 1997-2003 Ford F150
2 June 11th, 2011 07:39 AM
2000 Excursion Front Bumper change to 2005 billreedy Ford Excursion 1 March 5th, 2011 11:12 AM
Ford 8.8 Rear Differential Fluid Change DIXIE FIX Garage Talk: Shop Class 101 0 April 1st, 2010 11:11 PM
2000 , change , egr , f150 , ford
