Quantcast Fathers 2000 PSD - Ford Truck Club Forum
Old November 11th, 2011, 08:46 PM
Default Fathers 2000 PSD
Been tinkering on the 7.3, getting some of the little issues wrapped up, such as the vacuum to the hubs being lost causing his climate control to be stuck at defrost. Probably over working that little vacuum pump too.
Next (last?) problem this year is the radio has gone butt whacky, I haven't seen it turn itself on in months now. In those months its probably been driven 4 times...
Anywho, the radio was last seen acting intermittently, shutting off/turning on completely randomly. I've taken it out before and looked for a problem at the connections to the radio its self, nothing offered a solution.
Is there a common issue?
How can I find out if the radio unit its self is just bad?
Old November 11th, 2011, 09:42 PM
Images: 620
Liked 182 Times in 164 Posts
could be a bad internal connection or at the connector
unplug the connector and straight wire it to a 12V source and ground
Old November 12th, 2011, 02:17 AM
Why didnt I think of that?
lol
Old November 12th, 2011, 09:57 AM
whitesleeper's Avatar
Hay Klitch
Ok the radio take the radio out . and you will need to remove the face of the radio once you have removed it you will see how the faceplate gets power clean those contact points and put it back together . if that doesnt fix it then its the elec board inside the face plate . thats about 100 bucks at that point i would go after market 150 bucks will get you a nice kenwood head unit ..
hope this helps you
Old November 15th, 2011, 12:42 AM
DIXIE FIX's Avatar
Images: 504
Klitch im very glad you mentioned that lil bit about the vacuum lines to the hubs. Mine are out and just recently the air will only blow from the defrost. Is there any other issues that loss of vacuum can cause cause I can tell you right now it doesnt seem like the turbo has been running up to par.
Old November 15th, 2011, 02:28 PM
Originally Posted by whitesleeper View Post
Hay Klitch
hope this helps you
its the circuit board for the faceplate that has the issue? I've had it down to the main board under the cd/casette. I couldnt find any obvious needs for repairs there.
Unfortunately my father is a fan of keeping everything stock because the new replacement stuff has too many functions for him...
I haven't traced all of the vacuum lines, but what I seen was from the vac reservoir you have the line for the vacuum pump, then the other line comes up to a Tee, which then directly routes to the climate control while the other direction hits the 4x4 solenoid on the fender. I did not see a vacuum for anything else associated with that vac pump/res.
Old November 15th, 2011, 11:32 PM
sbellinghausen's Avatar
sbellinghausen sbellinghausen is offline
Images: 16
For the radio, you might try looking at the fuse. On my old '98 I had a very expensive aftermarket stereo that would turn on and off intermittently. I messed with it for probly 1 1/2 years before I figured out that an add-a-fuse I had used to power my satellite radio when I had the stock stereo had streched the prongs of the fuse holder apart and the fuse would make contact sometimes and wouldn't others. This may or may not be the case since he likes to keep things stock, but it's something else to check. Also, you might think about checking ebay or a junkyard for a stock replacement. I have one for an '06 but doubt it would work or you could have it...
ASwaff400 , deanc24 , DIXIE FIX , donee11 , DoubleDee , ericmiller181@gmail.com , JSoko , Klitch , Russo2 , sbellinghausen , skatebowd , whitesleeper
1963 Ford 2000 JSoko Ford's Not Listed 4 September 25th, 2011 08:42 PM
How to Change the EGR on a 2000 Ford F-150 JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:33 AM
2000 f150 3rd member * Terry G. 1997-2003 Ford F150
7 June 16th, 2011 08:55 AM
2000 F150 Windshield wiper problem hvykvy951 1997-2003 Ford F150
2 June 11th, 2011 07:39 AM
2000 Excursion Front Bumper change to 2005 billreedy Ford Excursion 1 March 5th, 2011 11:12 AM
2000 , fathers , psd
