Quantcast Where is OBD-I test connector? - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford Vans
Old July 17th, 2017, 12:33 PM
allkindsa's Avatar
allkindsa allkindsa is offline
Default Where is OBD-I test connector?
I am unable to find the OBD-I test connector in my '94 E150. My ChkEng light came on briefly while driving, and has since gone off, but I wanted to check if any OBD-I codes were stored.
There are other issues, but I thought I would start with checking codes.
I have scoured under the hood, driver-side around the pedals, passenger-side behind what I call the kicker panel. I have looked online and in my Haynes book, and I cannot find any connector in my van that resembles the connector pictures I see.
Any help is appreciated.
Old July 17th, 2017, 02:29 PM
Does it have the 4.9L? If so, check around the battery close to the coolant overflow jug. Tucked away in there somewhere.
Old July 18th, 2017, 02:02 PM
allkindsa's Avatar
Mine engine is 5.8. I'm led to believe I am to look for one like the attached image shows (labeled with STI, signal return, etc.) in someone else's engine compartment (near where you desribed). All I can seem to find is the light-gray rectangular connector shown in the other 2 images, and I found that connector behind the interior cover just forward of the passenger door.
ID:	1357   Click image for larger version
ID:	1358   Click image for larger version
Old July 18th, 2017, 02:20 PM
http://codes.rennacs.com/Petrol-Engi...n/Ford-EFI.php See if this helps any.
allkindsa , glc , harrison28 , Sonex74
hot rod test Hot Rod Magazine Hot Rod TV 0 December 2nd, 2013 06:51 PM
Hot Rod Test Hot Rod Magazine Hot Rod TV 0 December 2nd, 2013 06:51 PM
test BADSHOE BADSHOE Productions 0 January 1st, 2013 11:30 AM
test Jason General Discussion
3 August 13th, 2009 08:56 AM
connector , obdi , test
