Quantcast next small project - Page 9 - Ford Truck Club Forum
Old September 7th, 2018, 09:13 AM
Partial success boys! The ground strap was the cure all. Nothing like a $7 piece of wire to make you feel like a moron. It turned over,...but slowly. The battery charger I have doesn't have a high amp setting for jumping a vehicle off. I'll put it on the charger after work today and try to start it a couple of hours after. Just need to bleed the clutch and button a up a few small things. Gotta buy some 16" wheels. 15" tires are ridiculous!! The set I have on there should hold up for a little while though. I'll hopefully have something for y'all to see by Monday.
  #82
Old September 10th, 2018, 08:44 AM
So as I was using my remote start switch, I noticed the lower pulley was a little off. No luck getting it fired. Gonna replace that pulley. When I was trying it, with gas in the carb there wasn't even a glimmer of it firing. Gotta check for spark next.
  #83
Old September 14th, 2018, 10:12 AM
I was going over my wiring diagram and realized I had the wire for the coil resistor in the wrong spot. So I've got some spark now. Pulley works great. Starter crapped out on me (broke one of the mounting tabs). Probably didn't have it seated properly. Put one of my others in. Then the solenoid started sticking. Changed that with another that I had. It tried to start with a little gas down the vent tube on the carb. Put some fresh gas in the tank. Cycled the fuel pump a few times to check pressure at the regulator,..... started hearing splashing on the ground. Mistake I made while doing y new lines. Did get the clutch bled, but ran out of time to go get more line for the fuel. She's really close boys!
  #84
Old September 17th, 2018, 08:51 AM
She's running!!!! Got the fuel lines tuned up. Tried to upload a video for you guys. Guess I need to change the type of file it is. All that's left to do now is get the exhaust finished up. Got a coupe of pieces that need to be welded up before I put it together. I'll try to get that video up sometime in the next day or 2.
  #85
Old September 21st, 2018, 01:52 PM
I'm not sure how to change the video file. But I needed to install a mechanical oil pressure gauge as the electronic sending unit was not functioning properly. No need for the OD off button anymore. She's holding a perfect 55 psi. Think I'm gonna have to direct wire a switch for the fuel pump though. It starved itself out after a couple of minutes. Probably something in the harness that was on the engine that I'm not using now, so it wont keep running. Gotta wire up a switch for the reverse lights also,...unless i can find a wiring diagram for the harness from the old trans.
Name:	Inst. Panel.JPG
  #86
Old September 24th, 2018, 09:20 AM
Not sure why the other images didn't show before. Instead of putting in a switch for the fuel pump, I just wired the pump relay to stay closed when the key is in the run position. Bled the power steering system. Didn't get time to take care of the reverse lights. Once the I got the fuel pump straightend out, i was able to dial in my regulator. Pumps at a steady 7lbs. Coming along.
  #87
Old September 24th, 2018, 01:48 PM
Found a wiring diagram for the E40D neutral safety switch. Gonna try tagging into the reverse lights there before I put another switch in the cab. Be a lot cooler if I didn't have to manually turn them on and off when ever I'm backing up. Also ordered a tach today. Engine sounds like it's idling a little high. Probably the way it is set up for the ski boat application.
  #88
Old September 25th, 2018, 07:29 AM
Images: 620
Liked 182 Times in 164 Posts
well Chris,
sounds like you've been doing some head scratching and beer drinking
if you were closer I could come help with the beer
keep up the good work
  #89
Old September 25th, 2018, 08:42 AM
Correct on both accounts. I wish you were here to help,...not sure how much more my liver can take. As far as head scratching,...between the internet, my electrical background, and a little patience, I'll get there. Thanks for the support.
  #90
Old September 27th, 2018, 10:27 AM
Got the reverse lights worked out. Made me a short wiring harness from the old neutral safety switch to the reverse pins on the M5R2. Works like a champ. Tach should be in today. Took the wire that was hooked to the oil sending unit and landed it on the negative side of the coil. Routed it into the cab for the signal the tach signal. Dropped off some of the exhaust parts this morning, getting them welded up. Just need to put the hood back on and get the plate updated. Needs new tires, but I can kick around on the ones that are on it for a little while.
(View-All Members who have read this thread : 41
77carolina , axcell , bdscaocap , beefman , Bighorse , bigpapahh , blbokeb , Booba5185 , Dcsmith1922@gmail.com , dxmbcaocap24h , F100Chief , FOFO F-150 , ford40 , FordGuy1959 , Found_On_Richies_Driveway , FXRS , glc , gwfan , Hamilton Fordy , Hanknguyen , harrison28 , HATCH630 , Inside Man , IrishKRO , JSoko , Klitch , Lmadsen , MAmalfa , MarkV , mefreeman , Monkeyfinger , polargeek , Punisher1964 , ralph2854 , Shanevc , skatebowd , Steve1983 , The Bake , vietphanmem20588 , vjsimone , Yankee
Several small problems The Frankster 1992-1996 Ford F150
7 January 26th, 2014 10:54 PM
4-8-13 small update nflfreak43 1992-1996 Ford F150
3 April 8th, 2013 09:53 PM
How-To Rebuild the Top End of a Chevy 350 V8 Small Block Engine MOTORZ TV MOTORZ TV 1 May 5th, 2012 11:21 AM
How-To Tear Down a Chevy 350 V8 Small Block Engine MOTORZ TV MOTORZ TV 0 September 23rd, 2011 02:50 PM
project , small
