Quantcast loosing oil pressure - Ford Truck Club Forum
Old May 15th, 2013, 09:58 AM
cools's Avatar
cools cools is offline
Question loosing oil pressure
replaced oil pump, main and rod bearings. as truck heats up(to normal op temp) oil pressure goes down, then it sounds like a bottom end knock develops. If I keep the rpm's up oil pressure stays up. Can anyone help?
Old May 15th, 2013, 10:54 AM
Liked 99 Times in 96 Posts
What year and engine?
Old May 15th, 2013, 02:10 PM
^^^that, and also how low is the oil pressure dropping? What are you using to check the pressure?
Old May 15th, 2013, 02:24 PM
Cools, i re read your first post concerning this. It seems the issue remains with the low oil pressure even after all you've done. The only other suggestion I have would either be:
1. Cam bearings
2. Oil galley plug
3. main or rod bearing cap distortion, ovaled out or warped.
Did you plastigauge the bearings upon installation?
Old May 15th, 2013, 02:59 PM
Also, have you considered a complete rebuild? You may if the engine has high miles. Just my .02
Old May 15th, 2013, 04:09 PM
Images: 624
Liked 185 Times in 167 Posts
all the above +
check to see how much oil is in it
it may have leaked out
ASwaff400 , bikertrash3531 , Booba5185 , catmechanic07 , cools , glc , Hazzardousmat , JSoko , Rage58201 , Russo2 , The Frankster
How to Test a Manifold's Absolute Pressure Map Sensor JSoko Garage Talk: Shop Class 101 6 April 2nd, 2018 02:24 PM
Oil pressure dance. Russo2 1973-1991 Ford F150
42 February 21st, 2012 08:32 PM
High Pressure Oil Line ? JSoko 1999-2007 Ford F250 | F350
8 October 9th, 2011 05:10 PM
The Perfect Tire Pressure AutomotiveTV AutomotiveTV 2 July 6th, 2010 08:47 AM
Teen's beating death puts pressure on officials BigT67 General Discussion
10 September 29th, 2009 01:47 PM
loosing , oil , pressure
