Quantcast 1995 Ford F250 460 gas low RPM miss. - Ford Truck Club Forum
Old June 8th, 2016, 02:54 PM
nasblu's Avatar
nasblu nasblu is offline
Default 1995 Ford F250 460 gas low RPM miss.
I have a 1995 ford F250 460 gas engine truck with 75K miles on it that has developed a low RPM miss. I just replaced the plugs, wires, cap, rotor, fuel filter cleaned the injectors, new O2 sensor. Checked for vaccum leaks and still this miss. The miss goes away at higher RPMS. Anyone ever experience this any ideas. Was going to replace the EGR next???
Old June 9th, 2016, 11:17 PM
Ozzie's Avatar
Ozzie Ozzie is offline
You didn't mention if the miss started suddenly or gradually "came on". The added RPMs will likely camouflage the problem. If it's an actual "miss" it means that probably only one cylinder is affected. You can isolate the problem by interrupting the spark to the cylinders one at a time. Then you will know what cylinder is the culprit. If you can do a compression test, do it. That will tell you the health of the whole engine. If you get a low value on the same cylinder that is identified by interrupting the spark, then it is likely an internal problem, like a valve situation or a blown gasket.
baheinz , Bluegillfisher , Bulldog74 , glc , harrison28 , nasblu , Ozzie , Pjclaudet , skatebowd
1995 Ford F-150 radius arm bending Fordman16 1992-1996 Ford F150
1 May 15th, 2016 09:59 AM
Odd miss in my 88 f 350 bigduke6 1987-1991 Ford F250 | F350
1 February 24th, 2015 12:37 AM
1995 Ford F150, 5.0L, Engine Swap with Coyote 5.0L oflm 1992-1996 Ford F150
3 February 7th, 2015 11:43 PM
1995 ford f150 4.9 fuel problem Josh_petrovich 1992-1996 Ford F150
10 January 18th, 2015 02:25 PM
1995 f250 351W vac line leak big boy toys f250 1992-1997 Ford F250 | F350
2 May 19th, 2012 04:51 PM
1995 , 460 , f250 , ford , gas , low , miss , rpm
