Quantcast Gauge Opinions Needed - Page 2 - Ford Truck Club Forum
Old May 3rd, 2010, 02:03 PM
Originally Posted by RedHot150 View Post
idiot gauge or not, it's there. If he'd want to double up on an existing gauge...fine.
You can like them, but I detest the idea because I have too much money wrapped into my motor/trans. I don't know for sure but I think ford did the idiot gauges because people these days dont really seem to have any idea what is acceptable ranges. When my truck was stock, I didn't mind.
Although I'd love to have had the idiot gauges replaced with a functional gauge, in the cluster. that would be ideal for me since I've cut a corner and scared myself with my gauge pod when a vehicle popped up
Old May 3rd, 2010, 02:11 PM
Originally Posted by Webmaster View Post
Matt,
volt meter
fuel level
water/coolant temp
oil pressure
speedo
tach
is what I currently have.
klitch, guys, i think the three will be fuel pressure, air pressure and trans temp...
well you have it then, although the good thing is, if you change your mind you can always pop em back out. :)
Old May 3rd, 2010, 02:42 PM
I'd go with trans and coolant.
Even if you have them in the cluster the aftermarket ones are going to be more accurate then the idiot guages.
BATES
Banks & PHP Powered
Old May 3rd, 2010, 04:24 PM
2004FX4F150's Avatar
Images: 75
Just for what I was doing with my stereo systems in the past, a true volt gauge was a must. I instantly knew if there was a problem, I also had temp gauges for my amps.
You more than likely don't need these, but you were asking for ideas, thought I would throw them out there for ya.
Old May 3rd, 2010, 05:35 PM
No towing for me Klitch though trans temp is on the list just incase. [/CENTER]
even if your not towing, lifting the truck your trans temp still runs hotter than stock, runs about the same as a stock truck towing cause your workin the trans harder to spin them meats... i have a trans temp, water temp, and oil temp as my extra gauges.
that trans temp gauge saved me out on a trail one time. noticed the temp started to rise above 190 deg, stopped, looked under the truck, a log or rock hit the drain plug causing most of the fluid to drain out
Old May 3rd, 2010, 06:29 PM
pete59edsel's Avatar
Images: 101
Liked 6 Times in 6 Posts
Oil, Alt. and temp.
  #17
Old May 3rd, 2010, 07:38 PM
iPod meter, hair dryer monitor and cell phone guage!
BATES
Banks & PHP Powered
  #18
Old May 3rd, 2010, 08:19 PM
lilbit would need those and depth finder haha
90f150xltcenturion , akzep69 , norconut , Steven Stroup
3 July 21st, 2013 10:10 PM
3 July 10th, 2010 09:39 PM
paint advice needed BigTrouble 1997-2003 Ford F150
0 June 17th, 2010 08:35 PM
Fog Lights...Looking for Opinions MR_Pete 2004-2008 Ford F150
19 April 23rd, 2010 01:03 PM
Any Opinions for headlights and wheels? 2004FX4F150 2004-2008 Ford F150
21 October 31st, 2009 10:59 PM
gauge , needed , opinions
