Quantcast How to Change Your Brake Fluid - Ford Truck Club Forum
Old December 8th, 2011, 06:43 PM
Thumbs up How to Change Your Brake Fluid
Test your brake fluid and replace it if it's worn out, you can get a kit of test strips at the Auto Store
Test your brake fluid and do a replacement quickly and easily to restore it.
As with every other fluid in your car, brake fluid contains a main ingredient along with protective additives. The main ingredient in brake fluid doesn't degrade, but the additives do. The most important additive is a corrosion inhibitor. The corrosion inhibitor prevents internal rusting of steel brake lines, calipers and ABS (antilock brake system) components. Once the inhibitors are exhausted, even minute amounts of moisture can cause dangerous and costly corrosion.
Most car manufacturers recommend a complete brake fluid flush every two years or 24,000 miles. Rather than rely on a general recommendation, you can test the actual condition of your brake fluid. Remove the cover of the master cylinder and dip a strip into the fluid. Shake off the excess fluid and wait 60 seconds before comparing the color of the strip with the guide on the package. The guide tells you when it's time to change the fluid. Find a package of 25 BrakeStrip test strips at brakebleeder.com.
Changing Brake Fluid
You just need a test kit, a Turkey baster or syphon hose and fresh fluid.
I dont fool with the Test Kit, I just do it
Suck the fluid from the reservoir and refill with fresh fluid.
Some carmakers recommend replacing brake fluid every two years or 24,000 miles. Others don’t mention it at all. But it’s easy to test your brake fluid. Just dip a test strip into the fluid and compare the color to the chart on the packaging.
You can do a complete brake fluid flush yourself but its easier with a friend .
This procedure will replace all the old fluid with fresh.
Use a baster to suck out the dark brown brake fluid (brake and power steering fluids are incompatible, so use a different baster for each if you let the fluid get up in the bulb, cause your gona use that baster for the power steering flush, see next 'HOW TO'). Squirt it into a recycling bottle. Refill the reservoir with fresh brake fluid.
Then do a Bleed, read theses two differant threads to know how
http://www.fordtruckclub.net/forum/s...t=bleed+brakes
NOTE: DO NOT LET THE MASTER CYLINDER GO DRY, ALWAYS KEEP THE BOTTOM COVERTED WITH FLUID if not air will get in the system
NOTE: The brake fluid may damage the baster’s rubber bulb, so don’t suck the fluid all the way into the bulb.
*NOTE* Be sure to use the correct DOT number fluid recommed for your system; also do not forget BRAKE FLUID is a good paint remover, so be careful
ASwaff400 , bikertrash3531 , DoubleDee , HawaiianF150 , JSoko , marmaduke , Russo2 , Scorekeeper58
How to Change Power Steering Fluid JSoko Garage Talk: Shop Class 101 13 December 11th, 2011 06:35 PM
trans fluid change Stewy 39 1997-2003 Ford F150
13 July 10th, 2011 10:53 AM
Time to change the transmission fluid Bates88 Garage Talk: Paint & Detailing 5 May 24th, 2011 06:50 AM
Ford 8.8 Rear Differential Fluid Change DIXIE FIX Garage Talk: Shop Class 101 0 April 1st, 2010 11:11 PM
F150 Fluid Check With Lil' Bit 4x4 FordTruckClubTV FordTruckClubTV 0 February 8th, 2010 04:05 PM
brake , change , fluid
