Quantcast Power Stroke Filter on 460? - Ford Truck Club Forum
Old August 5th, 2013, 09:30 PM
ROB281's Avatar
ROB281 ROB281 is offline
Default Power Stroke Filter on 460?
Forgive me if the question is absolutely dumb but. . .
The IDI guys like running the FL1995 oil filter since it adds a quart to the total capacity, my question is would this filter fit on the 460?
Old August 5th, 2013, 10:12 PM
it will screw on as they are both 3/4-16 in
but they aint the same ford part #
drain back valve and gasket size may be differant
Old August 5th, 2013, 11:22 PM
NO question on this forum is Dumb!
Welcome to FTC!
Old August 6th, 2013, 08:41 AM
Welcome to FTC!
or as Dad would say "the only dumb question is the one not asked"
Old August 6th, 2013, 05:11 PM
ROB281's Avatar
aside from a bigger oil pan what else could I look at to increase capacity? the end result desired from this is cooler oil temps, I've read where adding an oil cooler would actually reduce oil pressure, so I don't think I want to go that route, unless that's not the case or the drop in pressure is actually not that bad or worth being worried about
Old August 6th, 2013, 06:23 PM
flush/clean the cooling system, install a new T-stat
lets keep the running temp down; this helps the oil (info on this site for flush & refill)
add an external cooler & YES if your engine is not internally tight the pressure will be lower with a cooler
tell us what you want to accomplish as in the type of driving your doing,
we dont know where your from; so you running in the swamp, hot sand, tall hills, slow go in the rocks, mall crawling
do you have an oil temp gauge and a pressure gauge??
Old August 6th, 2013, 08:48 PM
ROB281's Avatar
Highway running/ hauling in the Houston area
Only have a dummy gauge right now for oil
ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , glc , JSoko , ROB281 , Russo2
Mercury 90HP Four Stroke Outboard $3,300,Suzuki 200HP 4 Stroke Outboard Motor $5,100 motor1010 Stereo | Electronics For Sale
0 July 31st, 2013 07:12 PM
How to Stroke Any Engine - Stroker Science JSoko Garage Talk: Shop Class 101 0 May 18th, 2012 10:50 AM
Oil filter info and filter wrenches JSoko Garage Talk: Paint & Detailing 28 May 22nd, 2011 11:11 PM
Rumor: Ford May Increase 2011 Super Duty Power Stroke Diesel to 800 Lb-Ft of Torque Bates88 Garage Talk: General Tech Talk 2 July 21st, 2010 04:24 PM
460 , filter , power , stroke
