Quantcast Tuning '86 460 to Pass Smog - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford Vans
Old July 6th, 2017, 10:23 AM
Biggles's Avatar
Biggles Biggles is offline
Default Tuning '86 460 to Pass Smog
I've got a Cali 460 (Holley 4180) in a RV. First run round 2 years ago and the baby flew through smog.
Now, with gas that is about 1.5-2.0 years old in it, a "pre-test" was fine except high CO and high idle (everything else was higher than 2 years ago, but passable).
I ran the sucker down to about 2 gallons of gas in it, filled, put 2 cans of SeaFoam in it and ran it about 40 miles highway.
Lowered the idle from 1200+ to 850.
Sound fine. Anything else I can do before bringing it in?
Old July 6th, 2017, 02:03 PM
Images: 243
Liked 29 Times in 29 Posts
Run out fuel and replace with non ethenol fuel sometimes called "marine gas"
harrison28 (July 7th, 2017)
Old July 6th, 2017, 09:45 PM
Liked 27 Times in 24 Posts
Don't use Seafoam, it's too hard on the cats. Use Techron.
Agree - drain the fuel, change the fuel filter, and try to find some non-ethanol gas.
You may need a new O2 sensor.
Old July 12th, 2017, 01:08 PM
Biggles's Avatar
Had/have already run it out and filled with regular. No marine anywhere here. Up here in Northern California there seems be a little mischief going on by the state - a LOT of pre '99 smog machines are being locked out by the state and it's taking the shops weeks to get them fixed - IF they can, so I'm in limbo right now.
Old July 12th, 2017, 01:12 PM
Biggles's Avatar
Already have used SeaFoam
Did drain fuel - pretty much, vacuum tuned - sucker purrs.
No comp or O2 sensor.
Just a disconnected ERG valve - connected it to the only ported vacuum port I could find, and the Idle Tickler (High Idle Solenoid) is missing it's 12V switch, so I plugged the line, to get the idle to 850.
allkindsa , Biggles , glc , harrison28 , JSoko , skatebowd
Season 11 - Episode 16 - Twin Turbo Tuning Two Guys Garage Two Guys Garage 0 September 24th, 2013 09:20 PM
Tuning with a Vacuum Gauge BigBlue79 Garage Talk: Shop Class 101 1 January 8th, 2012 11:48 AM
Edelbrock Carburetors - Additional Tuning EdelbrockTV EdelbrockTV 0 November 4th, 2011 09:31 AM
Bama Custom Tuning - Exclusively at AmericanMuscle AmericanMuscle AmericanMuscle 0 August 14th, 2010 05:49 PM
Tuning 101 - Bama Custom Tuning at AmericanMuscle AmericanMuscle AmericanMuscle 0 August 14th, 2010 05:49 PM
460 , pass , smog , tuning
Powered by vBulletin® Version 3.8.6 Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
