Quantcast Need help creating the perfect 12" lift system (no blocks) - Page 2 - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-250 | F-350 SERIES | SUPER DUTY > 1992-1997 Ford F250 | F350
Old February 24th, 2012, 03:03 PM
Agreed.
With high center of gravity like that you can get yourself tipped over pretty quick. Along with the fact that those big tires will be super wide so you won't fit anywhere tight at all.
Huge lifts are street queens for sure.
Old February 24th, 2012, 03:26 PM
I'm up 8" and on 37's, I am only that high to keep myself from contacting metal components, which I need to notch a bracket I cut off some more to keep my panhard from contacting.
  #13
Old February 24th, 2012, 05:55 PM
But it is necessary for you to be that high since you did the sas.
With an OBS you can drop in a d60 with no lift at all and be good.
Old February 25th, 2012, 01:30 AM
DIXIE FIX's Avatar
DIXIE FIX DIXIE FIX is offline
Images: 504
Originally Posted by Russo2 View Post
Agreed.
woah woah woah, my truck was no street queen.
and honestly, i never had a single issue with even getting close to a rollover.
Have you donated to FordTruckClub.net yet? I have!
  #15
Old February 25th, 2012, 01:38 AM
Your truck also wasn't a crew cab long bed. See what I'm gettin at.
He said he won't be rock crawling, but I'm sure it could get all sorts of off camber when up that high half in half out of a mud hole being so long.
Old February 25th, 2012, 01:40 AM
DIXIE FIX's Avatar
Images: 504
thats true, plus my truck was almost 2.5 foot wider than stock so that helped tremendously
  #17
Old February 25th, 2012, 01:44 AM
With a d60 it won't be any wider than stock front and for some stupid reason the 10.25 is like two inches uh shorter on each side, a 2" wheel spacer is needed for the track width to be the same.
Old February 25th, 2012, 01:52 AM
DIXIE FIX's Avatar
Images: 504
yeah, but add my 2" wheel spacers, wheels 16.5x14 with 2" of back spacing and my 46x19.5 baja claws thats alot of tire sticking out on each side.
  #19
Old February 25th, 2012, 08:58 AM
So now you have a 20 foot long 10 foot wide box to be off roading. Don't sound like fun to me.
I just think 12" is way too much unless a street queen show truck, or a dedicated mud rig.
Any other form of offroad sounds risky.
(View-All Members who have read this thread : 19
antipop2621 , ASwaff400 , bassenator , BigBlue79 , Booba5185 , DIXIE FIX , DoubleDee , Dunecrazzy , herbz , joshua040403 , JSoko , Klitch , michaelsnodgrass18 , nine5flareside , Raleigh , ridindirty , Russo2 , skatebowd , SlydinClyde
How to "BURP" your cooling system Joe'Bronco Garage Talk: Shop Class 101 11 October 13th, 2018 09:47 PM
3.5" Lift CrazyD FTC Media Center
6 June 1st, 2011 03:23 PM
8"-10" lift springs for a 150 HellOnWheels Auto Parts Wanted
2 December 26th, 2010 04:15 PM
6" Rcd Lift and 5" Fabtech Blocks Agjake11 Garage Talk: Brakes & Suspension 22 January 10th, 2010 10:59 PM
New 2" Rear blocks Agjake11 Auto Parts For Sale
2 January 10th, 2010 10:56 PM
12" , blocks , f-250 , lift , mudder , off-road , system
