Quantcast 2001 Ford F150 SuperCrew 5.4 - Ford Truck Club Forum
Old October 29th, 2017, 07:08 PM
TCFord's Avatar
TCFord TCFord is offline
Default 2001 Ford F150 SuperCrew 5.4
My daughter was driving my truck when it wouldn't start. She waited a bit and it started and she stopped at another store at which time it would not start again no matter what. I towed it home. Basically the truck is a no start.
It does NOT click, does NOT crank, there is nothing. The battery is 9 years old and it seem to be bulging a bit so I purchased a new battery and still nothing.
Recommendations that I have already tried: to jump the starter relay on the firewall. It it cranks the starter, the starter is good and it is probably the relay. If nothing, then it is probably the relay. Well I didn't get anything from attempting to jump relay so I replaced the starter relay on firewall.
Was told that if it was the starter and I banged on it with a pipe or hammer just a bit, it would move the inside somewhat and this would reposition the bushings, gears so they would most likely start but it would be a one time thin and the starter would need replacing. I tried this and nothing.
After replacing the starter relay, now when I turn the key to start, it clicks in the area of the starter relay whereas it did not before (no sound at all).
Any ideas or suggestions would greatly be appreciated.
Thank you
TCFord
Old October 29th, 2017, 07:43 PM
Liked 98 Times in 95 Posts
Make sure the battery is fully charged.
Clean the battery terminals, and all connections from there to the starter and ground.
If that fails, pull the starter and go get it tested. A common problem is the ground strap down at the starter, it rots away.
harrison28 (October 30th, 2017)
Bulldog74 , glc , harrison28 , Roborob79 , TCFord , toastman540
2 questions on 2001 F150 Supercrew oldpops 1997-2003 Ford F150
1 July 6th, 2017 09:42 PM
Hey new here in orlando F150 Supercrew off road 2001 FordSupercrewOrlando New Member Introductions 7 May 7th, 2013 10:32 PM
'09 Ford F150 Lariat SuperCrew 4x4 Lifted SFssft1911 Vehicles For Sale
7 October 27th, 2011 02:28 PM
sub for supercrew f150 01f1502wd Stereo | Electronics For Sale
1 May 1st, 2011 08:13 PM
3V vs 2V in f150 (supercrew) vGnzlz 2009-2014 Ford F150
32 January 10th, 2011 01:42 AM
2001 , battery , f150 , ford , no start , solenoid , starter , starter relay , supercrew
