Quantcast 1983 F-150 2wd 5.0 2bbl Autolite 2150 carb Accelerator Pump Link Rod repair - Ford Truck Club Forum
Old June 20th, 2018, 08:30 AM
rivahmon's Avatar
rivahmon rivahmon is offline
Default 1983 F-150 2wd 5.0 2bbl Autolite 2150 carb Accelerator Pump Link Rod repair
I have a 1983 F-150 5.0 2wd with the Autolite/Motorcraft 2150 2bbl carb (E3TE-9150-AVA) and need to fix the accelerator pump rod. The OEM plastic rod end (clevis) broke and I can't seem to find just that part. An idea is to go with the old style "double 90" rod as used on the 2100 and possibly some 2150's from '59 til maybe '81.
The carb specialists have 4 1/2" and 5" rods of the old style which use clips to secure them to the throttle arm. My problem is determining the exact length as the throttle arm has 4 holes and the old plastic clip broke before I could see exactly how long the linkage was. I have a good carb kit that specifies the top hole "D" for maximum acc pump travel and the original rod was set to the next position down on the arm, "C". The carb is OEM and has never been touched and the pump rod measures 4 1/2".
Another idea was to use a rod end for R/C model cars which comes tapped to 3mm and simply re-tap it to match the 8-32 threads on the existing 1/8" rod.
I've been to the yards and they don't even know what a carb is anymore.
Thanks in advance for any insight.
Old June 20th, 2018, 11:21 AM
http://www.carburetion.com/sitesearc...%20Carburetors
About the 11th item down on the page. Hope this helps.
glc , harrison28 , rivahmon
1983 Ford F-150 5.8 351W Intake And Carb Swap What do I really have to put back? erickirchey 1973-1991 Ford F150
5 April 2nd, 2017 03:09 PM
1983 Floor Mat for sale styleside66 New Member Introductions 1 October 30th, 2013 06:15 PM
1983 Ford Repair Manual noswalsmada Auto Parts For Sale
0 June 1st, 2012 04:39 PM
78 4x4 351m, 2bbl carb please help! 2010Iron883 1973-1991 Ford F150
12 February 24th, 2012 11:39 AM
2150 Carburetor Rebuild Link BigBlue79 Garage Talk: Shop Class 101 1 September 20th, 2011 04:43 PM
1983 , 2150 , 2bbl , 2wd , accelerator , autolite , carb , f150 , link , pump , repair , rod
