Quantcast 5.4 3 valve issues - Ford Truck Club Forum
Old October 5th, 2018, 07:03 PM
pcreno's Avatar
pcreno pcreno is offline
Default 5.4 3 valve issues
Hi my name is Patrick , first time here just joined, I have an 07 250 that has no power in gear, idles fine revs up good no backfires but put it in gear and it does not want to stay running. if you do not give it any gas it will idle forward with no apparent problem until gas pedal pressed then it sputters and backfires. codes p0353 and p0357 still after changing plugs and coil packs.
Old October 5th, 2018, 08:14 PM
Liked 98 Times in 95 Posts
You have an issue with #3 and #7 coils:
https://www.obd-codes.com/p0353
https://www.obd-codes.com/p0357
Short to voltage or ground on COP driver circuit
Open on COP driver circuit
Loose connection at coil or broken connector locks
Bad Coil (COP)
Faulty Powertrain Control Module
What brand coils did you use?
harrison28 (October 8th, 2018)
glc , harrison28 , pcreno
PCV valve deleplank 1987-1991 Ford Bronco
4 July 22nd, 2013 12:21 AM
How to Clean the EGR Valve JSoko Garage Talk: Shop Class 101 0 January 4th, 2012 02:37 PM
How to Check the PCV Valve JSoko Garage Talk: Shop Class 101 12 December 24th, 2011 10:54 AM
PCV Valve test JSoko Garage Talk: Shop Class 101 0 June 1st, 2011 08:21 AM
EGR valve question... ASwaff400 1992-1996 Ford F150
1 September 21st, 2010 02:48 PM
coil pack , issues , valve
