Quantcast 1991 5.8 w with ovdrive tranny into 93 f250 - Ford Truck Club Forum
Old March 16th, 2019, 01:44 PM
Jmk33764's Avatar
Jmk33764 Jmk33764 is offline
Default 1991 5.8 w with ovdrive tranny into 93 f250
First let me start by saying hello to everyone and thanks. I have 1993 f250 4x4 5.8 with a c6 tranny. Motor is weak and tranny is solid but no overdrive. Sucks fuel bad. I also have a 1990 f150 4x4 with 5.8 and override tranny dont know if its aod or e40d. Its motor is rebuilt and so is tranny but the body is wrecked. My question is what do i need from donor truck in order to get it in my f250 as far as tranny. I know the motor will work. But not sure about the rest. Thanks.
Old March 16th, 2019, 02:44 PM
Liked 98 Times in 95 Posts
I'm 99% sure it's a E4OD. I don't believe that the 5.8 ever used the AOD, to make sure, check your door jamb sticker for the TRANS code. AOD is "T", E4OD is "E". Also, the AOD quadrant is PRN(D)D1, the E4OD is PRND21 with a separate overdrive lockout button.
Your issue is going to be the PCM and wiring. The C6 is not electronically controlled, the E4OD is. I don't know if you can simply use the F150 PCM and harness.
harrison28 (March 25th, 2019)
glc , harrison28 , Jmk33764
2001 f250 superduty tranny slips at anything more then 1/2 throttle homey433 1999-2007 Ford F250 | F350
6 April 8th, 2019 10:52 PM
1991 ford f250 fender flare suggestions & options mark raitanen 1987-1991 Ford F250 | F350
1 October 31st, 2018 02:10 PM
V-belt to Serpentine belt conversion on 1991 non turbo idi F250 Found_On_Richies_Driveway 1987-1991 Ford F250 | F350
2 August 9th, 2016 11:51 AM
1991 f250 witha 5.0 skinny116 1987-1991 Ford F250 | F350
7 August 24th, 2015 08:17 AM
1991 4.0 code 85 Klitch 1989-1992 Ford Ranger
0 March 20th, 2012 11:52 PM
1991 , f250 , ovdrive , tranny
