Quantcast Trailer wiring problem - Page 2 - Ford Truck Club Forum
Ford Truck Club Forum > GARAGE TALK > Garage Talk: Towing & Hauling
Old July 26th, 2010, 01:25 PM
I forget what year truck you have, but I havent seen Ford do seperate bulbs for the trucks in a while. I've always seen dual filament bulbs, which is essentially the same thing, you have two wires no matter what ya do.
Old July 26th, 2010, 01:26 PM
Nope. One bulb with two filaments to operate as running lights and brake lights
Old July 26th, 2010, 01:29 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
I have the same no tail light issue on both trucks: the 1990 and the 2000, both with the flat 4 plug.
So, the single bulb with dual filaments, will the converter kit I found solve the issue?
Big T
Old July 26th, 2010, 01:30 PM
BigT67's Avatar
Images: 262
WTF?!?!?!? it gave me the 30 second rule error message, then posted the same response twice!!
Big T
Old July 26th, 2010, 01:33 PM
Worth a shot. But i'd think those things were designed with the trucks like GM's or Dodges where the turn and brake bulbs are two separate bulbs....not dual filament bulbs.
I really dont get what this conversion kit really does, I mean when you have a dual filament bulb, you still have two wires to it. The same two signals your sending to the trailer.
  #17
Old July 26th, 2010, 01:34 PM
OH Bingo! That sounds more familiar
  #18
Old July 26th, 2010, 01:35 PM
BigT67's Avatar
Images: 262
the flat 4 has four wires, right? the conversion kit has five wires that go into this module that has the four connectors coming out of it.
Big T
  #19
Old July 26th, 2010, 01:40 PM
Right. Ground, left turn, right turn, parking/brake. The ground wire is the one that's reversed from the others (has the female end on the trailer side)...so you can't accidentally plug the connector in backwards.
That converter won't have any effect for you I'm pretty certain.
  #20
Old July 26th, 2010, 01:58 PM
BigT67's Avatar
Images: 262
OK, so it's back to looking for poor connections.......
Time to crawl back under the truck, updates to come later.
Big T
Bathexpert , Fordtruckman88 , gvfc2 , JSoko , Klitch , mschoppe67 , tjdinmaine
Trailer hitches nismo972 Garage Talk: Towing & Hauling 3 March 21st, 2010 11:09 PM
Truck U Custom TJ Trailer TRUCK U TRUCK U 0 February 1st, 2010 12:12 AM
Super Wiring Two Guys Garage Two Guys Garage 0 January 29th, 2010 08:59 PM
problem , trailer , wiring
