Quantcast 1994 Ford Ranger V6 4.0 liter automatic won’t start. - Page 2 - Ford Truck Club Forum
Old September 24th, 2011, 09:19 PM
Images: 627
Liked 185 Times in 167 Posts
when you get the old pump off look on the inside you can see where the seal is when they go bad it leaks out that little hole
one thing that will ruin a seal is useing that radiator flush stuff or any thing else besides anti freeze & destilled water ( yes use destilled water)
I'de flush the system before you take the pump off, but be carefull with the garden hose pressure you dont want to ruin your heater core
Prestone sells a plastic flushing kit where you install a tee in the heater hose and attach garden hose; start the engine & turn the heater temp on HOT; water comes out the top of the radiator
I also open the drain valve & any block drain plugs you can find
go ahead & install a new t-stat now & check hoses & belts & replace (I'de do this anyway for good measure) while ya got it apart
when finished let all the water drain out, close drain & install plugs and add the proper amount of Antifreeze followed by destilled water and let the air work out and add more water
take off or move what ever is in the way of the bolts to get the old pump off
usually if ya get the fan & clutch off the pump should clear
look at this
http://www.lmctruck.com/icatalog/fr/full.aspx?page=48
ASwaff400 , BornBlu , CrazyD , DoubleDee , HawaiianF150 , JSoko , nine5flareside , Patch87 , popee , rfraze , Russo2 , Scotts Black FX4 , skatebowd , whitesleeper , zack93ranger
1994 ford 4x4 5.0` bigjohn New Member Introductions 2 February 12th, 2011 09:00 AM
Ford Announces Mileage Figures for the 2011 F-150 3.7-liter V-6 and 5.0-liter V-8 Bates88 Garage Talk: General Tech Talk 0 October 18th, 2010 03:15 PM
2011 FORD HARLEY-DAVIDSON F-150 IS MOST POWERFUL, CAPABLE EDITION EVER OFFERED WITH 6.2-LITER ENGINE Bates88 Garage Talk: General Tech Talk 0 August 10th, 2010 02:40 PM
Ford to Debut Factory-Installed Remote Start Option on 2011 Super Duty, Heated Steeri Bates88 2011-2016 Ford F250 | F350
0 May 21st, 2010 02:38 PM
1994 , automatic , ford , liter , range , ranger , start , won’t
