Quantcast Timing chain issue - Ford Truck Club Forum
Old November 28th, 2011, 09:19 PM
Images: 243
Liked 34 Times in 33 Posts
Question Timing chain issue
I have started to hear some noise under the hood.Thought it might be an idler pulley.So i took off my serpentine belt, and have come to the conclusion that it is the timing chain.The old girl has 250,000 miles on her and all i have ever had to replace on the engine so far is the alternator.I am debating on whether to replace the timing chain,and water pump.Or just buying a new crate motor and being done with any up coming problems. Being that the old reliable 4.6L has so many miles and things are bound to start popping up.What do y'all think? i would like to hear everybody's 2 cents on this issue.
Thanks,Skatebowd
Old November 28th, 2011, 09:52 PM
Tough one. Maybe do a compression test and some other diagnostic things, send out a used oil analysis and stuff like that. If all else checks out with the motor just fix what it needs.
A crate motor seems like a hard price to swallow.
Old November 28th, 2011, 11:28 PM
whitesleeper's Avatar
2 cents worth find a 2010 5.4 and drop it in 390 hp
or just do a crate engine and be done 5 cents worth
Old November 29th, 2011, 05:27 PM
Images: 243
hey i just noticed that i put this in the wrong forum.supposed to be 1997 f-150 not 250 how do we change thread category?
Old November 29th, 2011, 08:42 PM
Seems someone beat you to the draw, but for the sake of it, see if you can move it using thread tools, being its your thread.
Anyway, the only problem with whites suggestion of the new 5.4 is then the supporting mods. Wiring, computer, trans. That would be cool though.
Is this truck still your dd or just a play toy? If it's a play toy I am all for gettin somethin bigger under the hood, maybe a warmed up 4.6 or a whipple charged 4.6/5.4 :headbang:
If it is a dd, keep it simple for the sake of reliability. I'm sure a whipple charged 5.4 is still more reliable than a truck like mine, but there goes your mpg
Old November 29th, 2011, 11:14 PM
Images: 243
i did not see any options that pertain to moves in the tool menu, but no worries its fixed already.And no she is not my daily driver.I thought about all the conversions needed to switch to the 5.4 that is why i opted on the 4.6L crate motor as an option. also agree on the modified version for more horse power.like you said i gotta be able to swallow the price.
Old November 30th, 2011, 12:09 AM
How much work and moolah is it to fix the timing chain now?
Maybe fix it, and start a rainy day fund for a new 4.6 and a s/c
Old November 30th, 2011, 10:16 AM
Images: 622
Liked 182 Times in 164 Posts
replacing the timing chain on these engines is not as easy with the 2 cams
read this, it will give you an idea of what needs to be done and see if you feel like doing it
http://www.fordtruckclub.net/forum/s...8323#post48323
Old December 2nd, 2011, 09:43 PM
Images: 243
Yea its quite an ordeal.Parts are about$400.00. plus i would put on a new water pump and belt and idler pulley/tension.Labor if some one else does it about $500.00.so just say $1200.00 because once you dig in you always find something else you think should be done.
Old December 2nd, 2011, 11:18 PM
But how does that compare to a whole new motor?
4.6 to 5.4 is a common swap too, I could dig up a whole write up for you if you want.
ASwaff400 , barryamon , BigBlue79 , BigT67 , Blktruck , Booba5185 , DoubleDee , f150man , GunSlingR69 , HawaiianF150 , JSoko , Klitch , losingmyhair , mikeg , MiracleMax , ONELOWF , rajahmun , Ridgerunner , Russo2 , skatebowd , swil73 , whitesleeper , wip
2004 Ford F150 VCT solenoid { Variable Cam Timing| Replacement...With Pics.! pete59edsel 2004-2008 Ford F150
52 December 26th, 2013 08:03 PM
Flooding issue BigBlue79 1973-1991 Ford F150
26 October 17th, 2011 02:36 PM
Timing Belts and Wiring Diagrams HawaiianF150 Garage Talk: Shop Class 101 0 September 6th, 2010 01:58 PM
Tonya Turk of So-Al Racing at the Loring Timing Association Hot Rod Magazine Hot Rod TV 0 August 19th, 2010 12:49 AM
Loring Timing Association Land Speed Racing Hot Rod Magazine Hot Rod TV 0 August 18th, 2010 06:57 PM
chain , issue , timing
