Quantcast Eliminate power steering - Page 3 - Ford Truck Club Forum
Old December 29th, 2011, 02:08 PM
WORLDWITHIN@VERIZON.NET's Avatar
WORLDWITHIN@VERIZON.NET WORLDWITHIN@VERIZON.NET is offline
AS AN UPDATE - I DID ELIMINATE THE A/C AND P/S PUMP FROM MY SERPINTINE BELT. STEERING EFFORT WAS SOMEWHAT DIFFICULT BUT, AT 10 MPH IT BECAME VERY MANAGEABLE. I REMOVED MY A/C. NEXT I WILL REMOVE THE P/S PUMP.I PLAN ON TAKING THE INPUT LINE TO THE STEERING BOX AND RUNNING IT INTO THE OUTPUT LINE.
I NEED TO KEEP THE BOX LUBRICATED. LATER I MAY REMOVE THE P/S FLUID AND PUT IN MOTOR OIL OR SOMETHING THICKER. I AM NOT SURE ABOUT THIS ? HAS ANYONE DONE THIS BEFORE ? DOES ANYONE HAVE ANY ,CONSTRUCTIVE, SUGGESTIONS ?
I WOULD APPRECIATE ANY THOUGHTFUL IDEAS. --- jim
  #22
Old December 29th, 2011, 02:43 PM
I like the hose loop idea, just make sure the threads are compatiable
leave the P/S fluid in there over useing oil
some gears and clutches prefer the fluid typically an ATF of the correct Type, be it Type 'F', Dexron, Mercron or Mercron II; then ya got some fro GM & Chrysler use
For those that dont know just as in Brake Fluid all ATF's are not compatiable
how dose the belt situation turning out, as in did you go with differant size belts to find the right one ?
  #23
Old December 29th, 2011, 07:58 PM
OK THANKS,J - I WILL GO WITH LEAVING THE P/S FLUID IN. THE FACTORY AND AFTER MARKET PEOPLE PRODUCE 2 LENGTHS OS SERP BELT. ONE LONG ONE FOR WITH A/C AND P/S AND ONE SHORTER ONE FOR WITHOUT A/C AND P/S. SO THAT PART WAS EASY ,I BOUGHT THE SHORTER ONE AND IT INSTALLED EASILY AND I'M RUNNING IT RIGHT NOW.
I WILL ALSO TRY TO GET 13 INCH WHEELS THAT ARE RELATIVELY NARROW FOR LESS WT AND STEERING EFFORT. I HAVE NOTICED THAT SOME CHRYSLER WHEELS HAVE THE SAME BOLT PATTERN BUT A LARGER AXLE (CENTER ) HOLE. I THINK THAT THERE ARE ADAPTERS MADE BY THE AFTER MARKET TO MAKE A LARGE CENTER HOLE SMALLER. BUT, I HAVE TO READ UP ON THIS OR CHECK AT A JUNK YARD ?
I THANK YOU ------ jim
  #24
Old December 29th, 2011, 08:21 PM
wheel adapters can spell trouble; when you change steering geometry your asking for trouble, stay with the stock wheels
meaning most outset the wheel to a uncomfortable stance/strain
causing ball joint wear amoungest other issues
  #25
Old January 5th, 2012, 07:06 PM
I agree,but i didnt mean adapters in the sense of- for example, the large heavy plates with lug bolts that changed the vw bug pattern to a chevy pattern to allow larger, wider wheels.
I should have said "inserts" which go in the wheel center hole to allow one wheel with a certain lug pattern to go on another vehicle with a smaller center hole. I know the tire repair people use these. But, i am not fully knowledgeable about them.
  #26
Old January 5th, 2012, 07:41 PM
What exactly is the point of all of this?
  #27
Old January 5th, 2012, 08:19 PM
Hotrod :headbang:
Just kidding I have no idea.
caps lock is fun though.
  #28
Old January 5th, 2012, 11:10 PM
"for less wt and steering effort"
  #29
Old January 6th, 2012, 11:55 AM
I WOULD LIKE TO DISCUSS THE "WHATS THE POINT" . I UNDERSTOOD THAT THIS WAS A FORUM FOR EXCHANGE OF KNOWLEDGE ABOUT VEHICLES IN GENERAL, AND RANGERS IN PARTICULAR. LIKE THE SONG SAYS - I COME HERE SEEKING KNOWLEDGE.
INCIDENTALLY I LEARNED TO USE ALL CAPS BECAUSE IT IS STANDARD PRACTICE IN THE ACCOUNTING AND TAX PROFESSION.
IM SORRY IF I OFFENDED ANYONE, BUT I ONLY KNOW SOME THINGS ABOUT THE MECHANICS OF VEHICLES. IF I KNEW EVERYTHING ABOUT VEHICLES, THEN I WOULD NOT BE HERE, I COULD JUST CONCENTRATE ON WRITING A BOOK ---( IN ALL CAPS )
THANKS, ------ jim
  #30
Old January 6th, 2012, 05:01 PM
THANKS, ------ jim
I hope no one was offended by the caps... that's silly if someone is.
As far as me asking "what's the point" , it's just a bit odd what you are doing BUT it is your truck so I was just curious what was the point of what you are doing?
We don't judge, just question!
A/Ox4 , ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , DoubleDee , HawaiianF150 , herbz , JSoko , Klitch , marmaduke , MartyleP , nine5flareside , Ol Red , Patch87 , Russo2 , skatebowd , WORLDWITHIN@VERIZON.NET
Power Steering (BOX) Klitch 1997-2003 Ford F150
18 March 23rd, 2012 01:11 PM
Saginaw Power Steering Pump Upgrade nine5flareside 1992-1996 Ford F150
7 March 26th, 2010 01:29 AM
eliminate , power , steering
