Quantcast 1994 ranger no start - Ford Truck Club Forum
Old December 9th, 2012, 06:59 AM
popee's Avatar
popee popee is offline
Default 1994 ranger no start
hi all
I have 1994 ranger 2.3 2wd I need wiring diagram or at least
the starting circuit the truck will not start without help the on fender solenoid lclicks when clutch pedal is depressed thanks in advance for any help pm me with a diagram or link or post on here
Old December 9th, 2012, 09:17 AM
It's either the neutral safety switch or the fender solenoid.
Old December 9th, 2012, 03:20 PM
popee's Avatar
thanks for your input I need to see a drawing showing the wiring of the starting circuit because I just jumpered 12v to the small wire on the starter while truck was in neutral and it started right up solenoid on starter picked and that is why it started sooo I would like to see routing of wires from ignition switch start position all the way to the starter solenoid that is on the starter by the way the iginition switch was in the on position when it started and I was able to turn it off with ign switch ty
Old December 9th, 2012, 03:33 PM
popee's Avatar
hi again can any one help me with a drawing for start/ign wiring or a link you can pm me or send me an email if this wiring diag is available on this site could you please tell me how to search for it because I have not found it as always thanks for any help ty
Old December 9th, 2012, 04:54 PM
I think this is what you're looking for.
FWIW, your issue sounds like the solenoid is bad. The good news is they aren't expensive and easy to replace. Good luck and to FTC!!!
Old March 31st, 2013, 02:37 PM
Tomsranger's Avatar
Tomsranger Tomsranger is offline
Any day above ground is a good day. Happy Easter.
Old March 31st, 2013, 05:07 PM
Images: 622
Liked 182 Times in 164 Posts
looking at he diagram and following the wires , it could be 4 things
1994-f150-bud , ASwaff400 , bikertrash3531 , Booba5185 , catmechanic07 , glc , JSoko , popee , RANGERDICK , rfraze , Russo2 , Tomsranger
1994 gauge cluster swap krick1961 1992-1996 Ford F150
10 December 30th, 2011 04:50 PM
1994 Ford Ranger V6 4.0 liter automatic won’t start. Patch87 1993-1997 Ford Ranger
10 September 24th, 2011 09:19 PM
1994 Ford Ranger Fuel Lin Leak FIX Patch87 1993-1997 Ford Ranger
0 September 24th, 2011 09:01 PM
1994 ford 4x4 5.0` bigjohn New Member Introductions 2 February 12th, 2011 09:00 AM
1994 , ranger , start
