Quantcast 1986 Bronco "Re"build thread. - Page 12 - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1980-1986 Ford Bronco
  #111
Old May 19th, 2012, 08:37 PM
I've checked everyone locally.. Even the salvage's, I found an almost new set at LKQ when I was there in April getting my Alternator and Fusebox, some a-hole stuck screws and nails in them....
  #112
Old May 19th, 2012, 08:38 PM
Ridgerunner's Avatar
Ridgerunner Ridgerunner is offline
Images: 60
Liked 4 Times in 4 Posts
Well that bites
1998 Expedition 5.4, 194 led light bulbs for the running boards.
  #113
Old May 19th, 2012, 08:51 PM
Originally Posted by Ridgerunner View Post
Well that bites
yep
  #114
Old May 20th, 2012, 12:44 AM
Think 31's are expensive..
Look at a 35x13.50x20
Old May 20th, 2012, 01:31 AM
I don't really care for really big tires, this was the grocery getter/haul everyone around vehicle til the pan gasket crapped on me for the 3rd time, now I also gotta replace the rear u-joints and yoke on the driveshaft, stupid double cardan joint.
  #116
Old May 20th, 2012, 09:19 AM
I'de go with a discount brand on sale
the size depends on you
and as Russo stated, the larger the tire the more green you shell out
  #117
Old July 27th, 2012, 05:45 AM
Been awhile since I've updated this, still working on the 351w, buying the parts I need when I can. We've come to the conclusion that the starter is being heat soaked by 1) the exhaust crossover coming from the driverside meeting the passengerside and then connecting to the cat, or what's left of it. Solution is, taking it down to the exhaust shop, having them get rid of the Y-pipe, and the hollowed cat, running the driverside bank down the driverside, and adding a muffler and new exhaust tip, it's all 2.50" exhaust BTW.
I'm torn between choosing a Thrush Turbo muffler or a Thrush Glasspack, the problem with the glasspack is, I'd have to have two welded on, meaning cutting off my Flowmaster 40, if I could find another 40 cheap I'd just forego all this muffler talk. Then I'm going to have two new Tips put on, should I go with the Jegs PSS Straight cut rolled end exhaust tip or should I go slanted tip? These won't be going straight out the back, they're going to be angled directly behind my tires.
  #118
Old July 27th, 2012, 07:40 AM
to maintain a free flow, a rolled tip would be out of the question
  #119
Old December 13th, 2012, 01:11 AM
Still planning on having the Bronco Dual Exhausted, have another Flowmaster 40 just sitting here right now, should happen in the spring, right after taxes hopefullyless I get money sooner. I'm going stainless slanted tips, and 2.5" pipe, no headers as dad doesn't want headers.
(View-All Members who have read this thread : 18
ASwaff400 , BigBlue79 , BigRob , bikertrash3531 , Booba5185 , chapter , DoubleDee , dsb12 , JSoko , Klitch , Petey D , Raleigh , Ridgerunner , Russo2 , skatebowd , Thomasstemmle , WORLDWITHIN@VERIZON.NET , yahnke
C-LIST 82 - 96 F150/Bronco 4" Lift - CHEAP nine5flareside General Discussion
1 July 12th, 2010 09:33 AM
Zappers 1993 Explorer Sport "Purple Haze" Pic heavy firezapper Ford Explorer 5 April 18th, 2010 12:11 PM
37" Toyo Open Country Tires Installed On 22" Rims Part 3 FordTruckClubTV FordTruckClubTV 11 February 11th, 2010 03:36 AM
37" Toyo Open Country Tires Installed On 22" Rims Part 2 FordTruckClubTV FordTruckClubTV 0 February 8th, 2010 04:05 PM
37" Toyo Open Country M/T Tires Installed On 22" Rims Part 1 FordTruckClubTV FordTruckClubTV 0 February 8th, 2010 04:05 PM
1986 , bronco , rebuild , thread
