Quantcast Running Rough - Ford Truck Club Forum
Old June 15th, 2016, 08:42 PM
Fords4ever's Avatar
Fords4ever Fords4ever is offline
Default Running Rough
First time posting have a bit of a problem with my old truck(not really old) I have been getting it back up running again after moving back to CA from AZ. Was having some very rough running issues under load.
Started with MAF cleaning , Cleaned throttle body and EGR,IAT and it started running a bit better still sluggish on acceleration , so I changed out the Fuel filter , Air Filter , Oil and filter.... and still has a sluggish get up , spark plugs where replaced about 2000 miles ago , and its not throwing any codes or CELs. anyone have any advice on this one ?
Thanks
Ken
Old June 15th, 2016, 11:51 PM
glc glc is online now
Liked 114 Times in 110 Posts
What exactly is your truck? Engine and transmission? Coil pack or COP? What brand plugs did you use? Have you tried Techron in the gas? Maybe a compression test? If it was sitting for a while, have you burned out the old gas and filled it with fresh gas yet?
Old June 16th, 2016, 11:46 AM
Fords4ever's Avatar
Default running rough
99 f150 4.6 Windsor, 2wd, 4r70w trans, replaced plugs 9 months ago with motorcraft but didn't do wireset going to grab a new set today. replaced old k&N air filter was not fitting tight, cleaned EGR , cleaned throttle body and IAT, cleaned MAF , checked all vacuum hoses no cracks or holes and all on proper places, Replaced Fuel filter ..... was trying to replace the cheap easy stuff first. ohh yea did a techron cleaner also. have not doing comp check as of yep. don't have the tools for that. oh and its 2 coil packs not COPs , and had added new gas recently.
Old June 17th, 2016, 09:32 AM
K&N filters can foul the MAF with oil. They also do not filter as efficiently as a dry paper filter and let a lot more fine dust through.
Fords4ever (June 17th, 2016)
Old June 17th, 2016, 12:03 PM
Fords4ever's Avatar
Default rough running
YES the old truck is back , after pulling the number 4 spark plug wire out it was almost ripped in half no clue how that happens. but it is back up and running great . Thanks GLC Yes the K&N is a problem for those MAF coils were packed with oil and very nasty Fram one I have NOW fits a lot better also hand to clean the inside of the housing out it had so much crap in it..
Thanks again
ken
Old June 23rd, 2016, 03:42 PM
gwfan's Avatar
gwfan gwfan is offline
What did you replace the K&N's with?
Old June 23rd, 2016, 08:59 PM
I think most of the problem with the K&N is the person doing the cleaning/oiling
I've been using that type for 10 years in my '06, no issues
Bluegillfisher , DoubleDee , Fords4ever , glc , gwfan , harrison28 , JSoko , logix89
slugish/no power/rough idle/bad gas millage judd94 1973-1991 Ford F150
4 January 14th, 2016 10:00 PM
5.4L 3V with miss, rough idle and codes P0340, P0344, P0345, and P0349 lindboep 2004-2008 Ford F150
8 August 18th, 2014 07:09 PM
Rough Idle, No power, black smoke??? adoporto 1992-1996 Ford F150
17 January 13th, 2014 11:41 PM
Hard start rough running Russo2 1973-1991 Ford F150
27 December 21st, 2012 07:48 AM
16 August 26th, 2012 10:44 AM
rough , running
