September 17th, 2013, 08:41 AM
Could have someone messed with her the ecm? My check engine light works but I'd think it would be on since the sensors aren't hooked up?
September 17th, 2013, 09:59 AM
Yes and no. The EECIV ecu's are kinda funky with codes. Your best bet is to repair/replace the Emission System. A Junk Yard will be your best friend for the A.I.R plumbing. You can get away with running without a cat for the time being as it will have no impact on sensor readings. The EGR valve I wouldn't trust from a JY. A smog pump from a JY would be ok as long as it spins freely without noise. These engines run more efficiently and last longer when these systems are functioning properly. As far as someone messing with the ECU, I highly doubt it as the MAP system ECU's have very little to no aftermarket support for tuning. Only other thing could be the previous owner replaced the ECU with an incorrect one but even then I'd think your situation would be worse.
September 17th, 2013, 09:19 PM
It has everything but smog pump and cat, I was going to buy vacuum hoses and start running them. Do indeed a smog pump for this?
September 17th, 2013, 09:44 PM
The Smog Pump provides the air needed to run the A.I.R system. Ultimately, through a series of valves it will pump air to the exhaust ports or to the cat. In the exhaust ports, the air will ignite the hot unburned hydrocarbons coming out of the cylinder. Without this, the O2 sensor will see this and cause the ECU to react accordingly. The air to the cat is to help "light off" the same hydrocarbons and assist the heavy metal catalysts in "scrubbing" the exhaust gasses. It also increases the life of the factory style cat. Since the cat is downstream of the O2 it is not needed at the time being and the tube that runs to the cat can be vented into the atmosphere, Its just air.
September 18th, 2013, 12:06 AM
Okay thank you. A smog pump is only $80 new so I'll pick one up and start to run all the lines
September 18th, 2013, 10:05 AM
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 12
bikertrash3531
Booba5185
Bulldog74
glc
JSoko
logix89
Moore1991bronco
purple lady
Russo2
shivey1
TwoStroke
Tyler.purrington
