Quantcast 1996 Bronco mirror wiring problem - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1992-1996 Ford Bronco
Old January 30th, 2017, 11:40 AM
Headwrench's Avatar
Headwrench Headwrench is offline
Default 1996 Bronco mirror wiring problem
Help.........I purchased new outside, power mirrors for my 1996 Ford, full size Bronco, XL. I am replacing both outside, power, rear view mirrors. No heater, no turn signal type. The existing harness has 5 wires and all new replacements have 3 wires. How do I make them work? I tried other vendors for mirrors and all have only 3 wires. Is this hopeless???? Should I return the new mirrors and give up?? .......I am new to this "forum" process and am not sure if I am using it properly.
Last edited by Headwrench; February 2nd, 2017 at 05:55 PM. Reason: no feed back. I don't know if I am using this "forum" process correctly.
Old January 30th, 2017, 12:38 PM
You'll get a better response by going to the forum page, and posting your questions in the appropriate category. Good luck.
Old January 30th, 2017, 10:41 PM
Liked 113 Times in 109 Posts
Moved to correct forum.
Old January 31st, 2017, 12:12 PM
Welcome to the forum, and I apologize if you aren't getting an answer right away. Please post only one thread per issue, I've edited the title of this thread for you to attract more attention. Hopefully someone will be by with the answer you need. Thank you!
Old August 27th, 2017, 11:09 AM
miesk5's Avatar
miesk5 miesk5 is offline
Yo,
Finally found this 3 wire 96 outside power mirror without led turn signal
by Ford for 96 Bronco & F Series
Iggie and tape the other wires.
96 Bronco XL 5.0 E4OD, Man Xfer/Hubs
See my partially recovered 78-96 Bronco/Truck web site . I need to clean up dead links & add many more new links some day. Thanks to Mr. Schwim!
Thanks to All Who Serve
(View-All Members who have read this thread : 70
Alexemami , AlfredHof , Alissahem , Allahemrt , Andrewbaicy , Anthonysib , Billygenna , BrianRed , BruceImmed , Carlosjekly , Carrollhof , Clydetaw , CraigOdory , DanielMum , DarrellUnsob , Davidrhync , DennisTed , Eltonnog , EmersonSwone , Franciswem , FrankCoosy , Frankmaide , glc , goldman , harrison28 , Headwrench , her , Hermanimact , HollisExord , holodblink , IgnacioSog , Jameshed , Jasonerona , Jimmyciche , Josephtok , karlhtx , KeithFoult , KelvinPriow , KevinRep , kotgar , Larrydib , Latiaspell , LiamMarry , LilaBar , mebelgar , MichaelJer , miesk5 , Nathanporse , RaymondDef , Raymondmub , RenatoVoics , Richardmor , RobertEmavy , RobertVog , Rodneyvat , RonaldFon , Russellasymn , SimaHyday , Svetlanabike , TELouis , TimmyJem , TimothyNut , tranpan12 , ValercoHalay , Vladimirfet , WilliamArows , Williamidons , Williamrhync , WilliamStali , XRumerTest
Trailer wiring problem BigT67 Garage Talk: Towing & Hauling 35 January 31st, 2011 04:21 PM
Wanting A 1979- 1996 bronco BigTrouble Auto Parts Wanted
7 June 17th, 2010 09:37 PM
1996 , bronco , mirror , problem , wiring
