Quantcast rear brake cylinder - Ford Truck Club Forum
Old September 29th, 2018, 08:31 AM
Kirt's Avatar
Kirt Kirt is offline
Default rear brake cylinder
I've changed the right rear brake cylinder on my 1993 f150. After trying to bleed the system I find that there is brake fluid leaking from inside. I mean that the leak is not from the connection of the brake line or the bleed valve. the fluid is leaking from the inside down onto the rim and down the tire. I'M thinking I did something wrong. Any Ideas?
Old September 29th, 2018, 10:02 AM
Sounds like you have a defective wheel cylinder. However, pull the drum and make sure that you reassembled the hardware correctly, you may have blown the piston right out of the end of the cylinder.
harrison28 (October 1st, 2018)
Old September 29th, 2018, 01:13 PM
Kirt's Avatar
Ok, I'll check that out.
glc , harrison28 , HiRoller , JSoko , Kirt
F-150 new OEM rear brake shoes have different thicknesses rivahmon 1973-1991 Ford F150
3 April 29th, 2018 10:49 AM
Ignition cylinder lock mike091791 1989-1992 Ford Ranger
4 October 21st, 2017 11:32 AM
Clutch master cylinder brick13 1992-1996 Ford F150
8 August 31st, 2013 12:06 PM
Rear brake rebuild - 87 F150 Scorekeeper58 1973-1991 Ford F150
5 May 6th, 2013 06:37 AM
F350 brake booster,m/c and wheel cylinder The Frankster 1992-1996 Ford F150
22 November 5th, 2012 03:09 PM
brake , cylinder , rear
