December 9th, 2018, 11:24 PM
Originally Posted by glc
The 460 and 7.3 use different bellhousing patterns. The 460 uses the 385 Big Block V8 pattern, the 7.3 uses the IDI pattern. I don't know if there's an adapter made for this or whether you can do some mods to get it to fit. If you can find a E4OD from a 7.3 4wd that should work. I do not know what is involved electronically - the E4OD does require a TCM, which I think is integrated with your PCM. It looks like the diesel has a standalone TCM.
I see all kinds of adapters for a Cummins to a E4OD, they aren't cheap.
So a cummins swap would probably be way easier?
December 10th, 2018, 12:19 AM
Liked 112 Times in 108 Posts
Not necessarily, but they are fairly common and there's a lot of info out there on it. A 7.3 and transmission swap would probably be relatively easy.
December 10th, 2018, 01:28 PM
Hmmmm...now I am torn as to what to do. I have been reading that doing a 7.3 swap would be a pain in the ass
December 10th, 2018, 04:27 PM
Not impossible though, because the 7.3 was an option in your truck. That means that parts to physically install it shouldn't be difficult to find.
December 10th, 2018, 04:45 PM
You are right. I have been reading conflicting stores, some say it's hell, some say it cant happen and some say it's easy.
I was hoping to be able to use my current transmission and transfer case as I just dumped all this cash into having them rebuilt.
December 10th, 2018, 05:49 PM
Thread Tools |
Display Modes |
Linear Mode
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Engine swap
Spyder |
Garage Talk: Engine & Drivetrain |
1 |
October 26th, 2017 11:00 AM |
Engine Swap
jmbeachner |
1999-2007 Ford F250 | F350
7 |
March 10th, 2013 10:01 AM |
460 engine swap
farmall |
7 |
June 5th, 2012 09:22 AM |
engine swap
460 Dream |
1992-1997 Ford F250 | F350
6 |
March 1st, 2012 09:40 PM |
300 I6 Engine swap
BigBlue79 |
29 |
January 10th, 2012 11:42 PM |
