Quantcast Track Bar Bushings: R&R - Ford Truck Club Forum
Old April 1st, 2019, 01:26 PM
asdato's Avatar
asdato asdato is offline
Default Track Bar Bushings: R&R
When replacing the Track Bar Bushings, does the original Bushing O.D. Steel Sleeve need to be removed from the Track Bar, or do the replacement Bushings use the old Steel Sleeve that's pressed into the Track Bar?
Old April 9th, 2019, 12:06 AM
Bill2's Avatar
Bill2 Bill2 is offline
Liked 4 Times in 4 Posts
Usually the sleeve is reused if buy neoprene. If using rubber some companies have the sleeve with it, if you use neoprene then add grease to sleeve and inside hole to eliminate squeeks
harrison28 (April 9th, 2019)
Old April 12th, 2019, 07:26 AM
asdato's Avatar
Thanks!
asdato , Bill2 , Bob S , glc , harrison28
SLS GT AMG On-Track Review - One Take TheSmokingTire The Smoking Tire 0 February 27th, 2013 04:11 PM
squeaking bushings a problem? skatebowd Garage Talk: General Tech Talk 4 October 29th, 2012 08:36 PM
Finally got to the track... F150GT 1992-1996 Ford F150
96 May 21st, 2012 01:03 PM
Alignment bushings Russo2 Garage Talk: Brakes & Suspension 3 May 8th, 2011 11:20 PM
Tuned Evo X Track Test TheSmokingTire The Smoking Tire 0 February 10th, 2010 06:23 AM
bar , bushings , randr , track
