Quantcast Fuel leak in 78 F50 new to me - Ford Truck Club Forum
Old April 5th, 2019, 10:43 PM
sbpbrent's Avatar
sbpbrent sbpbrent is offline
Liked 3 Times in 3 Posts
Default Fuel leak in 78 F50 new to me
While I am waiting on a tow truck, I better ask some more knowledgeable people about this. I was out after work driving near my house. I noticed the smell of gas, the tank level began dropping more rapidly than normal, then the truck stalled and won't restart. There is fuel under the engine compartment somewhere. It's too dark to see at the moment, but tomorrow, where should I look first? The only thing to narrow it down at the moment, is it appears to be leaking at the front. Basics: 1978 F150 standard cab, 400M, manual transmission. Thanks in advance! (All this the day after it passed emissions).
Old April 5th, 2019, 11:43 PM
Fuel pump or a fuel line. Ethanol is rough on old fuel systems.
Old April 6th, 2019, 09:48 AM
sbpbrent's Avatar
Interesting. I haven't found where it's leaking yet, but on LMC Truck I noticed that they have these listed:
Original material Pre-Bent Fuel lines.
Stainless Steel Pre-Bent Fuel Lines.
What's there looks like galvanized. Back to hunting and thanks! I will post some pics of my "new" truck after I get past this. I am not at all unhappy with it. Runs great and it:s pretty easy to work on (generally).
Old April 6th, 2019, 10:14 AM
It could possibly be a stuck float in the carb. Before you try to start it again, pull the dipstick and see if there's gas in the oil, that would indicate the fuel pump diaphragm.
Old April 6th, 2019, 08:32 PM
sbpbrent's Avatar
It looks like the fuel pump, EVerything's dry downstream toward the engine. Upstream is wet on the pump and a couple feet beyond. Then it's dry to the tank. I expected the pump to be on top of the tank and I first thought the pump was the fuel filter. It looks easy to replace where it is.
Old April 6th, 2019, 08:46 PM
The fuel pump is an old school mechanical pump. The fuel filter is screwed into the carb inlet. The fuel pump diaphragm probably ruptured and the fuel was spraying out of the vent hole in the pump. Wouldn't hurt to do an oil change, good chance some gas got into the oil.
harrison28 (April 8th, 2019)
glc , harrison28 , RustyPile , sbpbrent
Leak next to the EGR , Help Please ! Southern Swamp Boy 1992-1996 Ford F150
1 June 21st, 2017 09:57 PM
Transmission leak H Martin New Member Introductions 3 December 19th, 2016 01:20 PM
Transmission leak jsilva1987 1992-1996 Ford F150
1 April 19th, 2016 12:15 AM
bouncing fuel guage and other fuel related questions 90f150xltcenturion 1973-1991 Ford F150
0 February 23rd, 2013 03:50 AM
1994 Ford Ranger Fuel Lin Leak FIX Patch87 1993-1997 Ford Ranger
0 September 24th, 2011 09:01 PM
f50 , fuel , leak
