Quantcast Rubber Vacuum System Replacement (5.0\5.8 EFI) - Page 2 - Ford Truck Club Forum
Old April 19th, 2013, 01:12 AM
BoxerTwin's Avatar
BoxerTwin BoxerTwin is offline
This is the greatest post I have seen. The plastic lines I gave the finger to were not all in one piece. They had all crumbled as I was taking them out.
Great post, thanks.
Old April 19th, 2013, 01:18 AM
Anytime, if you need help with anything else on these trucks, start a thread and we will help!
Old April 19th, 2013, 08:52 AM
Great post, thanks.
that is a Great compliment for the Site and the Thread Author
Old April 20th, 2013, 12:56 PM
The Frankster's Avatar
Liked 12 Times in 9 Posts
I read that post over a year ago when I found out some of Booba's items in signature high lighted. Mine needs that too. Wish you could buy colored vacuum line. Just keeping it factory like ya know. I want to do the Saginaw swap also. Great story on your truck from a post in late 2011 also Booba.
Old June 11th, 2013, 09:15 AM
jpachla's Avatar
jpachla jpachla is offline
This is a great thread, except i'm not sure it applies to my 1990 e350 351w.
The vacuum source line on my evr is white. And it appears to have no vacuum.
Old June 11th, 2013, 10:50 AM
Where does the other side of the white line go?
  #17
Old June 11th, 2013, 10:54 AM
jpachla's Avatar
goes up and over to the canister under the passengers door,, but it turns to steel line just below the egr. And i have found that the lines disappear between the frame and body making it very difficult to see where they go.
Should the vacuum supply to evr always have vacuum?
  #18
Old June 11th, 2013, 11:30 AM
Yep, and so should the TAD\TAB solenoids. They all lead to the same place for supply, it'll go from the vacuum tree to the canister to the solenoids. Check to see if your canister has rusted out.
  #19
Old June 11th, 2013, 12:00 PM
jpachla's Avatar
ok, then. Looks like I have some detective work to do. my black and red from the canister have vacuum,, just not the white. and my canister is plastic. So I guess than only leaves one line to check.
Just for grins and giggles,,, could I pull a vacuum source from elsewhere to supply the evr?
Of course I realize that I still have to find the leak that is causing the white line to have no vacuum,,so guess it dont matter... just thinking out loud here
thanks for info,,, sometimes you get tunnel vision
  #20
Old June 11th, 2013, 12:09 PM
You could connect the EVR directly to the vacuum tree, but yea you still gotta find that leak. On some trucks, the EVR is connected to the vacuum tree stock.
(View-All Members who have read this thread : 74
1victoryrider , 87F150Jess , 87_f150_302 , 88dually , 90f150xltcenturion , 91klunkr , adoporto , Alloy Snake , Ashenden , barrett_s , big boy toys f250 , BigBlue79 , bikertrash3531 , Bill Traxel , Bluegoose , Booba5185 , BoxerTwin , Bulldog74 , Burton7.3 , chas87f150 , crisman , Dave8N in Pa , Desert dog , DON CHILDS , DoubleDee , EDMAN , elwray , emedlijn , EzPcC , frank5079 , FXRS , glc , goldman , GunSlingR69 , harrison28 , HawaiianF150 , Hemifish , HiRoller , IrishKRO , jhollow10 , jimmycrakcorn , joe250 , John Deere , Johnny F , jpachla , JSoko , Kaotik , KC9RFO , lanejesse85 , Littlem , logix89 , Longbeach4x4 , memphoman , MichiganF250! , Moore1991bronco , mrmessma , Mtgoat , nine5flareside , purple lady , Red91 , rick wilcoxson , Ridgerunner , Russo2 , scbill , Sprabary , stro , The Beast , The Frankster , TwoSpeed , Tyler.purrington , Upstate bronco guy , vjsimone , willie197140 , zach
fuel injected 5.8 vacuum routing BeauxLeachman 1992-1996 Ford Bronco
6 December 20th, 2016 03:07 PM
9 July 13th, 2013 12:25 PM
Quick Tip - Replacing Rubber Grommets Gearz Gearz 0 August 4th, 2011 04:17 PM
Quick Tip - Splitting Rubber Tubing Gearz Gearz 0 August 4th, 2011 04:17 PM
Big rubber JSoko 2004-2008 Ford F150
1 October 14th, 2010 03:25 PM
efi , replacement , rubber , system , vacuum
