Quantcast 80-96 F-150\Bronco Brake Booster Replacement\F350 Swap - Page 3 - Ford Truck Club Forum
  #21
Old October 10th, 2012, 10:05 PM
Your O'reilly's doesn't price match Rock Auto? Mine does.
  #22
Old October 10th, 2012, 11:41 PM
Don't have a local oreilly's
A friend has the extra 350 stuff since he makes all his trucks hydroboost, I will get the parts from him pretty cheap.
Old October 10th, 2012, 11:42 PM
I hear you can rebuild the master cylinders, my dad used to do it instead of buying new ones, that might be a cheaper alternative.
  #24
Old October 11th, 2012, 12:09 AM
Doubtful, you can also rebuild these brake calipers, or get an already rebuilt life time warrantied one for 20 bucks.
Which reminds me, do you know if the one ton dual piston calipers will bolt on? Both use slide pins.
Old October 11th, 2012, 09:10 AM
They won't clear 15s, you'd have to get 16s, and still grind the calipers a bit.
  #26
Old October 11th, 2012, 11:14 AM
Ah didn't think about that. Oh well.
Old October 11th, 2012, 04:10 PM
we used to re-build anything & everything on Tractors, motorcycles, cars & Trucks
tractor & motorcycle parts were interchangeable with automotive parts and were cheaper
we found that as times changed we could get new or re-manufactured parts with a warranty for a couple more bucks and less down time
  #28
Old October 11th, 2012, 04:13 PM
NAPA is the only place I've seen that actually still sells rebuild kits for Master Cylinders, everyone else has stopped. Samething with starters and alternators, no one carries rebuild kits anymore.
  #29
Old October 11th, 2012, 05:08 PM
not around here, yet
  #30
Old October 11th, 2012, 07:40 PM
What would need to be ground to fit on a F150? Would any grinding be necessary on 17" wheels?
(View-All Members who have read this thread : 33
87_f150_302 , 88dually , BigBlue79 , BigTrouble , bikertrash3531 , Booba5185 , Burton7.3 , CountryBumkin , DoubleDee , elwray , HawaiianF150 , HiRoller , irish12671 , jjanow2000 , JSoko , ktm126 , Longbeach4x4 , Lostin90s , Lukemaynard01 , Melvin Pepperdash , nine5flareside , Petey D , PGAPRO , Picklopolis , Red91 , Ridgerunner , rivahmon , Russo2 , Snyiper , The Frankster , TNT , whitesleeper , willd
Ford BRONCO 3rd brake light install Joe'Bronco Garage Talk: Shop Class 101 9 June 10th, 2011 01:36 PM
Tie Rod Replacement DavidS827 1997-2003 Ford F150
5 September 9th, 2010 05:30 PM
Oil and Air Filter Replacement and Maintenance nine5flareside Garage Talk: Shop Class 101 0 March 5th, 2010 01:09 AM
LED replacement bulbs RedHot150 2004-2008 Ford F150
16 August 20th, 2009 08:39 AM
Replacement Panels??? Tirekiller 1992-1996 Ford F150
5 July 29th, 2009 07:00 PM
8096 , booster , brake , f150bronco , replacementf350 , swap
