Quantcast 96 fsb5.8 cooling system problem - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1992-1996 Ford Bronco
Old December 17th, 2012, 06:53 PM
gtstang's Avatar
gtstang gtstang is offline
Default 96 fsb5.8 cooling system problem
I have issues with my cooling system. I noticed the smell of antifreeze after a 20mi trip poped the hood seen fluid on top of the overflow tank. The upper hose was hard so i figured thermostat, replaced no help. Any ideas would help
Old December 17th, 2012, 07:19 PM
you did install the t-stat correctly with the spring toward the hose
another overheating issue would be fan not working, or the pump not working
or if you have been out hunting and rode through a field to pick up that big Deer the weed tops could be clogging the radiator fins
take the cap off the radiator and see if the tubes inside are clogged up
if this just started I'd say fan or pump
Old December 17th, 2012, 07:28 PM
The only other thing i can think of is the impeller on the pump is worn out. Has it been replaced? Or possibly a clog in the heater core? Or just a little over full? Has this been a reoccurring problem or isolated?
Old December 17th, 2012, 09:40 PM
gtstang's Avatar
I just got the bronco not to long ago it has 175000 I bought it from the original owner they said water pump was replaced not to long ago when I start it and try to remove the cap when its still cold it starts overflowing
Old December 17th, 2012, 09:52 PM
Stuck or messed up Thermostat or improperly installed one.
Old December 17th, 2012, 10:02 PM
^^^ x2
Old December 18th, 2012, 10:07 AM
A brand new t-stat can be bad right out of the box
you can check one before install by putting it in a pan of water and heating it up on the stove
use a thermometer to watch the temp and when it gets up to 190+ degrees it should be wide open
or try running the engine without the t-stat
Old December 18th, 2012, 10:10 AM
I'll bet, if you remove the t-stat it wont over flow
Old December 21st, 2012, 06:49 PM
gtstang's Avatar
I just had a chance to play with my Bronco its not overheating I just think its building excess pressure I could be wrong I also have a problem with fuel system I have to cycle the key 3-4 times before it'll start I put a pressure tester on had no pressure then KOEO first time 19psi second 23psi third 30psi and KOER about 30-32psi
ASwaff400 , BigBlue79 , BigRob , bikertrash3531 , Booba5185 , goldman , gtstang , JSoko , Moore1991bronco , Russo2 , simperfi762
Understanding The Cooling System nine5flareside Garage Talk: Shop Class 101 0 March 5th, 2010 12:49 AM
cooling , fsb58 , problem , system
