Quantcast PCV valve - Ford Truck Club Forum
Old April 17th, 2013, 03:19 PM
deleplank's Avatar
deleplank deleplank is offline
Default PCV valve
Where in the heck is it located on a 302?
Old April 17th, 2013, 03:50 PM
Passenger side valve cover on the rear, under the intake plenum. If you haven't done so already, now is a good time to reroute it.
http://www.fordtruckclub.net/forum/s...ead.php?t=6049
Old April 17th, 2013, 05:16 PM
good info/advice in the above link
Old July 22nd, 2013, 12:10 AM
EzPcC's Avatar
EzPcC EzPcC is offline
Question
I am curious about the oil/water separator you added in your post
http://www.fordtruckclub.net/forum/s...82&postcount=4
I expect oil residue but where would the water be coming from? Also where did you get it from and did you need to also get an adaptor to mate with the rubber hose..?
Thanks.
Old July 22nd, 2013, 12:21 AM
I've actually changed that setup a bit. I picked up a different separator and mounted it. I just used some barbed 1\4" NPT fittings I had laying around to connect to the PCV hoses. The separator I bought at harbor freight was similar to this:
http://www.harborfreight.com/air-too...ter-68225.html
Here's how it is run now:
The water in most cases is just condensation that builds up in the oil from the PCV breather (on the driver side valve cover). Keep in mind if you have a MAF truck you have to have that breather connected to your air tube so the MAF sensor meters the air being used.
bikertrash3531 , Booba5185 , deleplank , elwray , EzPcC , glc , JSoko , Russo2
How to Clean the EGR Valve JSoko Garage Talk: Shop Class 101 0 January 4th, 2012 02:37 PM
How to Check the PCV Valve JSoko Garage Talk: Shop Class 101 12 December 24th, 2011 10:54 AM
PCV Valve test JSoko Garage Talk: Shop Class 101 0 June 1st, 2011 08:21 AM
EGR valve question... ASwaff400 1992-1996 Ford F150
1 September 21st, 2010 02:48 PM
244.00 valve covers an no pcv port chatterjj 1992-1996 Ford F150
7 January 3rd, 2010 08:43 AM
pcv , valve
