Quantcast 87 Bronco XLT 5.0 4X4 Problems - Ford Truck Club Forum
Old September 15th, 2013, 01:43 AM
Tyler.purrington's Avatar
Tyler.purrington Tyler.purrington is offline
Default 87 Bronco XLT 5.0 4X4 Problems
I recently bought an 87 Bronco XLT and the 4X4 doesn't work, It has the push button 4X4. Any help with a wiring or any help?
Old September 15th, 2013, 02:44 AM
I have a 2x4, so I haven't had to deal with 4x4 problems much. That being said, I see the have a lot of problems when the shift actuator. It either completely goes out, or you have bad connections going to it. When you push the 4x4 button does anything happen at all? Climb under the truck and look at the connections going to the transfer case, unplug them, clean them and plug them back in.
That's what I'd do to start, at least.
Old September 15th, 2013, 10:48 AM
If it has the automatic hubs, if you don't have to manually turn them, they are notorious for failing. There are kits to convert to manual. Warn is a good one. I would follow Booba's suggestion first as it costs nothing and may fix it.
Old September 15th, 2013, 09:35 PM
I have checked my wires and cleaned them and still nothing, I have planned on changing over to manual but first I want to figure out why it isn't engaging
Old September 16th, 2013, 06:28 PM
Is the 4X4 light not coming on? There is an electric shift motor on the BW 1356 transfer cases. These motors are prone to failure. Check the relays and check for voltage at the switch and the shift motor.
Old September 16th, 2013, 08:03 PM
No, the light uses to come on when I started the truck but now it doesn't come on at all and when it did it didn't feel like it was in 4X4
Old September 17th, 2013, 08:47 AM
As far as the light is concerned, it could be just burned out, but I still think you should check for voltage at the switch and the shift motor. One or the other will tell the light to turn on. I'm leaning towards the shift motor to do it.
Old September 17th, 2013, 09:38 AM
Does the 4X4 switch run through a computer or does it do straight to the transfer case?
Old September 17th, 2013, 10:07 AM
That, I'm unsure of. I know the 97+ trucks had one called a GEM.
Old September 17th, 2013, 12:30 PM
IIRC the switch on the dash is powered by +12V, and it just actuates the Transfercase Motor, no computer. It sounds to me as if it is the electric motor, IDK if you can do this on newer(electric shifted)transfercase's, there's a trick you can do to see if it's your transfercase itself or your hubs, put the transfercase in 4hi, climb under the truck, spin the front driveshaft left(towards the driverside)it should take no more than 6-7 turns and stop spinning, that'll tell you it's engaging, now if it's still spinning, listen near the hubs while spinning it, you'll hear near the back of the hub a "click" sound, the hubs aren't engaging.
But like I said, that's for a Manual Shift T-Case, haven't tried it on an electric shift one.
BigBlue79 , bikertrash3531 , bmad01 , Booba5185 , Darren Brown , elwray , glc , harrison28 , JSoko , Klitch , Moore1991bronco , Russo2 , Scorekeeper58 , The Frankster , TwoStroke , Tyler.purrington
1996 Ford Bronco - Starting Problems!!! 1rockman 1992-1996 Ford Bronco
3 September 11th, 2012 07:26 AM
94 bronco fuel problems scott h 1992-1996 Ford Bronco
6 December 4th, 2011 08:41 PM
94 Bronco Engine Problems sellerskyle 1992-1996 Ford Bronco
7 May 31st, 2011 02:47 AM
94 Bronco starting problems sellerskyle 1992-1996 Ford Bronco
7 November 16th, 2010 03:50 PM
More problems.... V8_Feller 1997-2003 Ford F150
2 May 17th, 2010 03:54 PM
4x4 , bronco , problems , xlt
