Quantcast Rusted out core support - Ford Truck Club Forum
Old September 16th, 2012, 02:10 PM
HiRoller's Avatar
HiRoller HiRoller is offline
Default Rusted out core support
So my radiator core support is badly rusted out, more so on the battery side. I see this to be common as all of the junk yard trucks have the same issue, which is what got me looking at mine.
Any sources to find a quality replacement ?
Old September 16th, 2012, 02:24 PM
lmctruck.com , but I've heard that they have some customer service issues, and are pretty high priced.
Old September 16th, 2012, 02:57 PM
^^^ what he said, and some of their parts are made overseas and not one of their body parts are CAPA certified. Try you might get a deal there or National Parts Depot. They're prices are close to the same as LMC but better Quality.
Old September 16th, 2012, 03:02 PM
www.nationalpartsdepot.com Is whom I'd order thru if they have it, I got my magazine from them here the other day. Way higher quality products then LMCTruck..
Old September 16th, 2012, 04:14 PM
Images: 622
Liked 182 Times in 164 Posts
you can make one useing a metal wall stud and selftapping screws
Old September 16th, 2012, 08:39 PM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
I agree with Joey! I was gonna say he same exact thing but he beat me to it. While your at it.....use some rubberized undercoating before you put it on to keep future rust off. If you dont want to do that.....def use some rustoleum paint and a good top coat.
Black Sheep of FTC
Old September 16th, 2012, 09:02 PM
Images: 622
use foam water pipe insulation
Old September 16th, 2012, 10:53 PM
Common on any obs truck in the rust belt. If it's a gas truck the LMC or other resto place will have one, diesel you will need to find one in a yard. I would personally find someone to get you one from the south or try ebay. Paint it with something anti rust before installation.
Old June 15th, 2013, 10:56 PM
HiRoller's Avatar
Well it's been a while but I finally got R done, I bought mine from LMC truck, It wound up being the cheapest with the freight charge, about 275.00, I tore into it and it was way worse than I thought it would be, I did have have to weld in a patch for the mount on the passenger side, It was shot. I bought a set of poly bushings while I was at it I figured, what a bear those cab mounts are, I fabbed a puller at work and drank much beer on the drivers side rear cab corner. Now that it's done I find I need to shim up my bed about an 1/8 inch to restore the body line. On to the Belltech stuff now, weather is great for the moment so onward !!!!
1992 Nite Style Side SB 5.0 E4OD
2014 Fusion SE Ecoboost
Old June 16th, 2013, 01:18 PM
Lostin90s's Avatar
Any generic parts outfit will have them way cheap than most posted here . I have replaced several over years . My current one has been on for 6 year no rust just under coated and spray oil in those cant reach places every year .I get mine from local wrecking yard or through body shop . I have luck to have raybuck.com in my back yard . Look around and save shipping . My 1 local supplier has 2 sitting right now .
As for used if not from Texas like state probably be same. Soak those mount bolts several times a week for couple week first they take longest to get out.
(View-All Members who have read this thread : 21
95f150 , asdato , ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , cammed farm truck , catmechanic07 , glc , HiRoller , jones03100 , jsach , JSoko , Kaotik , Lostin90s , Merfman , michaelsnodgrass18 , polargeek , Russo2 , Sclove ford , The Frankster
Heater Core Klitch 1997-2003 Ford F150
11 September 11th, 2012 05:17 PM
How to Install a Heater Core Bypass Valve Booba5185 Garage Talk: Shop Class 101 1 February 4th, 2012 08:37 PM
How to Remove a Rusted Bearing Assembly JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:11 AM
Pickup Bed Crossmembers Rusted jak1604 FORD F-250 | F-350 SERIES | SUPER DUTY 0 May 1st, 2011 12:15 AM
Need You All To Show Support! nine5flareside General Discussion
4 December 16th, 2010 09:27 PM
core , rusted , support
