Quantcast Lightning Instrument Cluster Swap - Ford Truck Club Forum
Old October 28th, 2011, 02:30 PM
The Frankster's Avatar
Liked 12 Times in 9 Posts
Default Lightning Instrument Cluster Swap
I want to go to the 120 speedometer. Instead of swaping out the whole cluster, a Lightning for my 93 with tach, can I just swap out the speedometer. Does the Lightning tach have a higher reading tach? I forget. Whether the whole cluster or just speedo what other change will I have to make? The PSOM comes to mind. Finding a cluster in excellent shape is probably unlikely and I would bet you cannot get the speedo from Ford any more. Thanks in advance. Franklin
Old January 27th, 2012, 08:54 AM
Lostin90s's Avatar
The posom should do it.
There have been people selling re calibrated 120 mph posoms. I know you can recalibrate for tire size but having enough adjustment to go to 120 MPG . not a clue .
As for condition any cluster can be cleaned up . Its the plastic outer that makes look bad .
Good luck
78f1504wd , BigTrouble , Booba5185 , bruewayne , Burton7.3 , Drewz94 , HiRoller , JSoko , KC9RFO , Klitch , Lostin90s , nightshade , Russo2 , sbellinghausen , SnowDaddy , The Frankster , wicat3 , willd , woodrock
1995 f150 Instrument Cluster Mod - TEASER nine5flareside 1992-1996 Ford F150
5 January 30th, 2012 11:10 AM
1994 gauge cluster swap krick1961 1992-1996 Ford F150
10 December 30th, 2011 04:50 PM
1980-1986 Instrument Cluster w/ tach BigBlue79 1973-1991 Ford F150
3 September 18th, 2011 02:31 AM
1980-1986 Instrument Cluster w/ tach BigBlue79 1980-1986 Ford Bronco
0 September 17th, 2011 06:17 PM
How To Center Shift Pointer Needle In F150 Instrument Cluster DIXIE FIX Garage Talk: Shop Class 101 5 November 28th, 2009 05:42 PM
cluster , instrument , lightning , swap
