Quantcast 95 instrument cluster swap = alternator not charging - Ford Truck Club Forum
Old December 29th, 2011, 07:28 PM
nightshade's Avatar
nightshade nightshade is offline
Default 95 instrument cluster swap = alternator not charging
I swapped the instgrument cluster on my truck (1995) for for an instrument cluster with a tach. This came out of a pick a part place. I think this cluster is from a 92-93? Everything works except the alternator is not charging. I saw a thread that discussed the need to swap four wires on the instrument cluster, but it did not say which ones. Does anyone here know which ones I should swap?
Thanks for your help in advance - nightshade
Old December 30th, 2011, 02:55 AM
CrazyD's Avatar
CrazyD CrazyD is offline
Images: 198
If no one knows the best way to figure it out would be to get a haynes manual for both year models and look at the wiring diagrams. Im sure you could figure it out from there.
02 F150 5.4L - Lots to come soon!
Old December 30th, 2011, 02:37 PM
There is a diode or resistor in the cluster(I forget which one), you'll have to find which circuit or is an put a jumper in. It lets the batt light come on briefly to switch the voltage regulator on. I had to do that when o put a 93 cluster in my 95...
Old December 30th, 2011, 03:08 PM
NightShade, I swapped out my cluster in my 1995 F150.
For the 94 - 95 F-150 you will need to stick with a OBD I cluster from a 94 - 95 truck. 96 is OBD II so that answers that question and 92 - 93 F-150's are also interchangeable (I'm sure the same applies to Bronco's). You can also use a 94 - 95 lightning cluster that has a 120 MPH speedometer. That will make your F-150 35 MPH faster with no engine mods! (just kidding)
Crazy D, good to see you back!
Old December 30th, 2011, 03:45 PM
skatebowd skatebowd is online now
that's just funny right there I don't care who ya are
Old December 30th, 2011, 06:05 PM
CrazyD's Avatar
Images: 198
^^ that is truely funny.
95 - thanks, its good to be back.
Old January 27th, 2012, 08:59 AM
Lostin90s's Avatar
Also the 95 96 year I ran into late 95 with a 6 code and early 96 with 5 codes .
1994-f150-bud , ASwaff400 , BigTrouble , Bluegoose , CrazyD , DoubleDee , JSoko , Lostin90s , nightshade , nine5flareside , Russo2 , sbellinghausen , skatebowd , whitesleeper , wicat3
1995 f150 Instrument Cluster Mod - TEASER nine5flareside 1992-1996 Ford F150
5 January 30th, 2012 11:10 AM
Lightning Instrument Cluster Swap The Frankster 1992-1996 Ford F150
1 January 27th, 2012 08:54 AM
1980-1986 Instrument Cluster w/ tach BigBlue79 1973-1991 Ford F150
3 September 18th, 2011 02:31 AM
1980-1986 Instrument Cluster w/ tach BigBlue79 1980-1986 Ford Bronco
0 September 17th, 2011 06:17 PM
How To Center Shift Pointer Needle In F150 Instrument Cluster DIXIE FIX Garage Talk: Shop Class 101 5 November 28th, 2009 05:42 PM
alternator , charging , cluster , instrument , swap
