Quantcast How much would it cost to have the slave cylinder in a clutch changed.. - Ford Truck Club Forum
Old June 15th, 2015, 12:34 PM
XLTAlex's Avatar
XLTAlex XLTAlex is offline
Angry How much would it cost to have the slave cylinder in a clutch changed..
it hurts... i cant believe im about to ask........ its painful....... but... how much roughly would it cost to take in an f150 with a 302 cu engine and have them only change the slave cylinder... ow.. i just died a little on the inside...
Old June 15th, 2015, 12:53 PM
Liked 113 Times in 109 Posts
It's not the cost of the slave, it's the labor. The tranny has to come out. If you are going to go through all that, I'd consider replacing the whole clutch assembly unless it's relatively new.
A full clutch rebuild in a shop is about $1200.
Old June 16th, 2015, 12:52 PM
XLTAlex's Avatar
Ok... i am going to do it myself.. its a new assembly but i think the guy that sold it to me put a cheap one in just to sell it.. Is there anything else i should do with the transmission is dropped? And where would be the best place to get a new assembly or just the slave cylinder..
This one looks exactly like the one that is on there now.
http://www.ebay.com/itm/Perfection-C...1b1f72&vxp=mtr
Then i am probably going to buy this one unless i would be better off getting it somewhere else...
http://www.ebay.com/itm/OEM-NEW-1993...888fbd&vxp=mtr
Old June 17th, 2015, 12:37 AM
Rockauto.com:
LUK Part # LSC003B
One of our most popular parts
5 speed trans.; Release Bearing and Slave Cylinder Combination
$33.79
LUK is Ford OEM.
Now - what's wrong with your slave?
Old June 22nd, 2015, 04:32 AM
gwfan's Avatar
gwfan gwfan is offline
Default Wow!
Wow! Does that already include the parts or just the labor itself?
Old June 22nd, 2015, 09:05 AM
Parts and labor.
Old June 24th, 2015, 03:34 AM
gwfan's Avatar
Oh I see. It's really expensive.
Old August 10th, 2015, 08:57 PM
XLTAlex's Avatar
The slave cylinder is leaking
Old August 11th, 2015, 10:55 AM
it's not that hard to do as long as you have the space to do it in. i did my 88 myself. if i can do it,...just about anyone can. just need to get someone to help you bleed the slave afterwards.
Old August 11th, 2015, 12:27 PM
Right, it's very labor intensive though. The transmission and bellhousing have to come out to get at it.
67 Merc 4x4 , ASwaff400 , BigT67 , glc , gwfan , harrison28 , JSoko , KevinThype , latemade5.8 , skatebowd , steve95 , XLTAlex
Leaking clutch slave cylinder XLTAlex 1992-1996 Ford F150
2 June 24th, 2015 03:07 AM
Clutch master cylinder brick13 1992-1996 Ford F150
8 August 31st, 2013 12:06 PM
'95 F250 4x4 slave cylinder issues... 1977 F-250 4x4 Custom 1992-1997 Ford F250 | F350
3 January 6th, 2013 11:14 AM
Changed connecting tie rod, steering is off. nine5flareside 1992-1996 Ford F150
9 March 11th, 2010 04:13 PM
changed , clutch , cost , cylinder , slave
