Quantcast Bed Removal - Ford Truck Club Forum
Old September 5th, 2016, 04:01 PM
TnFord's Avatar
TnFord TnFord is offline
Default Bed Removal
I have to remove the bed on my 1996 F150 Supercab to replace the front fuel pump. My rear fuel pump is filling up the front tank. I have removed the bed before on a Ranger but was wondering if anyone can tell me how many bolts and what size hold the bed on a 1996 F150? I crawled under and looked but didn't see as many as I thought I should.
Old September 6th, 2016, 09:24 AM
so there ain't any bolts (4 or 6) on the bed
remove fuel neck and wiring (lights)
find some help and lift it off
I may be easier to just drop the tank
just get it low on fuel to make it lighter
some times the bed bolts wont move & strip or break off
Old September 6th, 2016, 06:27 PM
TnFord's Avatar
Thanks for the info JSoko.
I did one once by dropping the tank and had a hard time reconnecting the fuel lines and wires. There wasn't enough slack to hook up the wires and hoses when the tank was down. When you put the tank up into position where the wires and hoses would reach there wasn't enough space to get your hand in to hook them up. Plus you couldn't see very well to make sure everything was connected.
I guess I will try to raise the bed but if the bed bolts strip or turn I will drop the tank.
Thanks.
Old September 7th, 2016, 05:12 AM
If the bolts won't move easily
spray and let them sit awhile
other option would be to cut them off, or shear/break them off with extra leverage
Old March 5th, 2017, 09:06 PM
TnFord's Avatar
Default Bed removal
I finally got around to replacing the front fuel pump last weekend. If anyone is about to attempt it, the nuts underneath are 18mm. I had to get some universal sockets to get them all and had to take a side grinder to one of them. I jacked the bed up, put 4x4's between the bed and the frame, and slid it to the rear about 2 feet for access. I didn't have to drop the bumper. I didn't lift the bed all the way off like most people do because it has a heavy lid and bed liner on it. It took about 2 weekends since I had trouble with the bolts but it is in and working fine now.
Old March 9th, 2017, 10:13 AM
great
(View-All Members who have read this thread : 13
67 Merc 4x4 , 96lt4at , BlackTruckDave , DoubleDee , Flareside95 , frank5079 , gfinch1050 , glc , harrison28 , JSoko , ncranchero , The Frankster , TnFord
Dash Removal lanejesse85 1992-1996 Ford F150
7 November 5th, 2014 01:03 PM
Emissions Removal Ridgerunner 1973-1991 Ford F150
12 April 13th, 2012 08:12 PM
Seat Removal: '04-'08 DoubleDee 2004-2008 Ford F150
1 July 29th, 2011 06:57 PM
paint removal The-LI-Redneck Garage Talk: Paint & Detailing 1 April 28th, 2010 09:36 AM
Adhesive removal? 2004FX4F150 Garage Talk: Paint & Detailing 22 March 9th, 2010 11:31 PM
bed , removal
