Quantcast Installing a SubWoofer in a '09 F150 SCab - Ford Truck Club Forum
Old September 6th, 2009, 11:43 PM
Default Installing a SubWoofer in a '09 F150 SCab
Hey all,
Im looking for information on how to install a subwoofer under the back seat of my supercab that includes all the wiring. I'm hoping the wiring is limited to tapping into exisiting rear speaker wires and only having to route a power wire to the battery.
I dont want to spend a lot and I only want to increase the bass range. I'd like to keep the factory equipment. I dont have any knowledge of whats a good sub. I dont want to blow the windows out just increase the bass. 50 watts is prolly mor'n enuff for my needs.
Any suggestions?
Old September 7th, 2009, 09:53 AM
A few things we need to know:
1.What head unit do you have?
2.What speakers do you have in the truck?
3.What is your budget?
Depending on your budget and need, you may just be
better off replacing you factory speakers with better
quality standard speakers.
Old September 8th, 2009, 01:25 AM
Thats sort of what i wanted to avoid. I have the factory 6cd chg system. All i really want to do is beef up the sub range a little. i was sort of hoping to keep the factory head unit and speakers and just add a small sub under the rear seat.
Old September 8th, 2009, 01:27 AM
i prolly should have reread your post. you think it might be better off changing out the factory speakers.
in the past i have done just that and although i did get better speakers i still didnt have the low range i was looking for.
im hoping to this as cheap as possible.
Old September 8th, 2009, 07:56 AM
We can find you an affordable setup but first you need to answer my three questions and I will explain why after you answer them! Answering these three questions will help us greatly in knowing what the next step is.
Old September 8th, 2009, 09:09 AM
he pretty much answered the first 2 questions....and kinda the 3rd
factory 6 disc headunit...factory speakers...and cheap.
Old September 8th, 2009, 03:21 PM
Cheap is #1 in my wallet! Thanks RedHot!
Ya Webby,
1. is factory 6 disk Cd Changer
2. is factory speakers
3. is as cheap as it gets - i prolly want to stay below 150 bucks total, i dont want to spend alot. Just what is needed to add a sub to the factory audio system.
I got a good system at home and with the road noise, babbling riders and the sirens of approching cops. I figure too loud is just well, too loud.
Old September 8th, 2009, 03:53 PM
OK what I was looking for are make and model numbers the headunit and speakers so I can view the specs of each item. If you are on a budget and have standard/stock Ford speakers in your truck, my suggestion to you is upgrading those before you do anything else. I would go with any newer model speakers from Alpine. I only use alpine in my truck and they have never let me down in quality for dollar. Even my head unit and amps are Alpine. You could probably replace all your truck speakers for about 200 - 250 thats about 4 speakers. You wont regret the sound.
Now if your head unit has RCA outs you can run an RCA cable to an active bass tube and hid it behind your rear seats. Bazooka makes an affordable powered bass tube. Again cheapest and best route in your budget.
If your head unit doesnt have RCA outs then you should start with upgrading your truck speakers then move onto the head unit. My head unit was a little over 1000.00 dollars, touch screen, navigation, dvd, cd, camera all that stuff. You need to think long term when buying a new head unit. What do you want out of it?
Old September 8th, 2009, 10:31 PM
Im pretty sure my factory head unit has no RCA out jacks. A RCA converter is prolly in the area of 20-40 bucks. What i dont know is since the converter has four speaker wires do i need to tap into both rear speaker wires? Why couldnt i just tap into one side of the rear speaker wires, say the rear side speaker wire i plan to mount the sub on. In my case it would be the right side rear speaker wire.
My son's friend - ah oh - the dreaded used but new guarranty coming from young kids - has a 8 inch bazzoka for 150 with all the wiring. Im thinking about.
1. its from a kid so you just gotta know its been blasted past mars!
2. it's not old, it predates godzilla.
3. 150 bucks is too high for a used 8 inch bazzoka sub.
4. will a 8 inch bazzoka tube fit under my rear seat.
Old September 8th, 2009, 10:40 PM
Does it come with an amp? And does your head unit have RCA outs? Also do a general search on the internet for what an 8" bazooka will run you. As far as it fitting under your seat... gotta get the trusty tape measure out. Even if it was a good price you still need to know the specs of your head unit. You cant just run a line from your rear speakers to your bazooka. Lets do this the correct way. Get the model number of your head unit so we can pull up the specs.
DoubleDee , JerryR , mrbassdan , nine5flareside , offroadpanda , quick98gtp , Sands611 , whitesleeper , windigowolf
Installing 4.88 Gears in a 9.75" Rearend DIXIE FIX Garage Talk: Shop Class 101 3 January 12th, 2010 09:40 PM
Installing and Setting Up an Amplifier SoundScape Garage Talk: Shop Class 101 0 November 27th, 2009 11:25 PM
f150 , installing , scab , subwoofer
