Quantcast 95 150 rear suspension - Ford Truck Club Forum
Old December 4th, 2011, 08:06 PM
tity04's Avatar
tity04 tity04 is offline
Default 95 150 rear suspension
Any suggestion on getting heavier load capacity . i get terrible drop with a load. i hear f250 springs will give me ruff ride.Have same issue with my e150. i was thinking of air shox .
Old December 4th, 2011, 09:24 PM
you can get them helper springs and they work great for the price
I've used these and they work, I carry alot of feed, dirt, heavy tongue weight from trailer & poo
http://www.jcwhitney.com/loadpro-adj...terid=d18911j2
Old December 4th, 2011, 09:34 PM
whitesleeper's Avatar
might look at a set of firestone helper air bags ....
fillem when you needem deflate when you dont ....
about 250.00 bucks unless you go with onboard air system then add another 200.00 bucks SAFER AND STRONGER THEN AIR SHOCKS ....
Thats my 2 cents worth
Old December 9th, 2011, 12:02 AM
I can second this, I used them when I moved across the country. When I had my muffler install they installed it at the wrong angle so when the truck is under load it grinds on the driveshaft. These kept the rear end from sagging considerably, and fixed the problem.
Old December 9th, 2011, 12:35 AM
I tell ya, I could probably use some over load springs..
That was only about 800 pounds, granted it's mostly aft axle with those three big beams, but I have had close to 1500 in the bed before.
I'm a picture... junkie..
90f150xltcenturion , ASwaff400 , Booba5185 , bruewayne , DoubleDee , F150GT , JSoko , michaelsnodgrass18 , Russo2 , tity04 , whitesleeper , wicat3
Lightning suspension on a 90 LWB bikertrash3531 1973-1991 Ford F150
6 October 4th, 2011 05:07 PM
The Perfect Chassis Suspension AutomotiveTV AutomotiveTV 0 April 7th, 2010 12:40 AM
NEW - Edelbrock Suspension Products EdelbrockTV EdelbrockTV 0 February 8th, 2010 04:52 PM
Roadmaster Active Suspension Kit Scotts Black FX4 2004-2008 Ford F150
4 August 5th, 2009 05:49 PM
150 , rear , suspension
