Quantcast How to Change Air Filter - Ford Truck Club Forum
Old January 29th, 2012, 10:03 PM
Thumbs up How to Change Air Filter
Do this 10 minute job yourself and save $30
Replace your air filter in minutes. And vacuum out debris while you're at it.
1: Open and Vacuum the filter box
Remove the air filter and vacuum out any dirt.
2: Check the air filter
Hold the filter in front of a shop light. If dirt blocks more than 50 percent of the light, replace the filter.
Told that your engine air filter needs replacing? It may be true. But testing your filter is easy and replacing it is a brainless task—so do it yourself. Replace the filter based on its actual condition rather than the manufacturer's recommended service intervals. Checking its condition isn't rocket science. Just pull it out and give it a look-see. If it fails the back-light test, replace it. While the filter is out, vacuum out the crud in the air cleaner box
Bluegillfisher , Derwood , jamesgang , JSoko , Russo2 , wicat3 , XRumerTest
How to change your CAI Filter HawaiianF150 Garage Talk: Shop Class 101 3 May 28th, 2014 09:49 PM
Oil filter info and filter wrenches JSoko Garage Talk: Paint & Detailing 28 May 22nd, 2011 11:11 PM
Replacing Fuel Filter DIXIE FIX Garage Talk: Shop Class 101 4 April 19th, 2011 07:18 AM
Oil and Air Filter Replacement and Maintenance nine5flareside Garage Talk: Shop Class 101 0 March 5th, 2010 01:09 AM
What kind of oil and filter do you use? nine5flareside Garage Talk: Paint & Detailing 72 October 10th, 2009 09:14 PM
air , change , filter
