Quantcast Alternator Replacement: When to Listen to Your Mechanic - Ford Truck Club Forum
Old July 21st, 2012, 07:18 AM
Exclamation Alternator Replacement: When to Listen to Your Mechanic
When replacing and alternator, other upgrades are worth doing too
Go ahead and change the serpentine belt, tensioner and idler roller when replacing an alternator on your car or truck. Better to do it now than later
Worthwhile upgrades
1.Idler rollers & Belt Tensioner
Examine idler rollers for wear patterns. If you see wear, they're not spinning freely.
You bring your car in for a new alternator and the mechanic wants to change out the serpentine belt, the tensioner and the idle roller too. Is it worth it?
Yes. Your mechanic is actually looking after your best interests . Belts, tensioners and idler rollers rarely last the life of the vehicle . The additional labor for the idler roller is minimal (about $10), and the labor for the tensioner usually runs about $50. If you plan to keep the vehicle, you'll save money in the long run by replacing these parts now.
bikertrash3531 (July 21st, 2012)
Old August 17th, 2012, 11:42 AM
davigf's Avatar
davigf davigf is offline
Is replacement of the idler pulley difficult? Is it just a bolt on? Or do I have to mess with a spring?
George
davigf's Avatar
1994 F150 inline 6
George
Old August 17th, 2012, 12:12 PM
It's a bolt on replacement, there is a spring inside, but you don't mess with it. The idler only fits on one way, and you bolt it down, thats it.
Old August 17th, 2012, 11:47 PM
you can also just replace the bearing
but it has to be pressed out & in
I'll try to find the bearing # I have it in a pile of notes
Old August 17th, 2012, 11:48 PM
most bearings have #'s that can be use for a replacement
Old August 18th, 2012, 12:14 AM
On the pulley yes, but the springs wear out over time, I know because mine did.
Old August 18th, 2012, 10:04 AM
yes the spring is just as important as the bearing
and as cheap as a whole replacement is that would be good insurance for the next 100,000 miles
Old August 18th, 2012, 10:08 AM
and to answer your question the idler replacement is not difficult at all
removing/releasing tension on the belt would be the most difficult and can be done at the idler with a socket & breaker bar
do not remove the belt unless its cracked or worn, just slp it off the idler
now if your belt has moare than 60,000 miles I would replace it with a GoodYear Gatorback belt
there is a thread on this also try a search
BigBlue79 , bikertrash3531 , Bluegillfisher , Booba5185 , catmechanic07 , davigf , JSoko , Klitch , marmaduke , michaelsnodgrass18 , Red91 , TnFord
do i need a new alternator? bikertrash3531 1992-1996 Ford F150
20 July 20th, 2012 07:17 PM
Battery or alternator? Russo2 1973-1991 Ford F150
44 December 19th, 2011 10:02 AM
3G Alternator Upgrade BigBlue79 Garage Talk: Shop Class 101 18 October 16th, 2011 01:55 AM
Alternator Died alaskatabby 2004-2008 Ford F150
7 March 16th, 2011 10:10 AM
When the wife don't listen Scotts Black FX4 General Discussion
5 September 20th, 2009 09:50 PM
alternator , listen , mechanic , replacement
