Quantcast Door sills - Ford Truck Club Forum
Old November 28th, 2012, 09:16 PM
Eng89ine's Avatar
Eng89ine Eng89ine is offline
Default Door sills
What has the group done to eliminate the scuff marks on the door sills. It seems no matter how you try you end up hitting the sill. While searching for trucks the used one have taken a beating and now since I have seen so many with the same issues I figured I would try avoid it. I went to a sign company and asked how much a 6x29" strip would be. I was told that a thicker stock would work be it has to be printed out black (I was told it was a white sheet to start with) let me know
Old November 28th, 2012, 09:23 PM
Most aftermarket parts houses like Jegs, Summit, JcWhitney, etc, carry door sill protectors from universal to vehicle specific applications in different materials. I'll dig some up.
Old November 28th, 2012, 09:26 PM
Here's some that Summit carries.
http://www.summitracing.com/search/p...ford/year/2012
Stylintrucks carries a cheaper alternative for $38
http://www.stylintrucks.com/parts/st...avs/2094.aspx#
Old November 28th, 2012, 09:28 PM
Eng89ine's Avatar
I have seen some online though the only ones I have seen that completely cover are the chrome ones. I would prefer black.
Old November 28th, 2012, 09:32 PM
As small as they are, powdercoating isn't all that expensive and it will last.
Old November 28th, 2012, 09:46 PM
Eng89ine's Avatar
Ah! I like that. There is a shop in my area. I will just have to stop in now. Networking at its best. Thanks
Old November 28th, 2012, 09:55 PM
my '06 has a clear plastic strip on both sides from the factory
that seems to be indestructible
Old November 28th, 2012, 10:00 PM
Old November 28th, 2012, 11:51 PM
3m makes some sort of stuff you can put on different parts of the truck or whole truck that protects, like what Jsoko has. I have no idea what it's called, but a lot of (most of) newer trucks have it on critical points that see a lot of rocks and road dirt etc
Old November 29th, 2012, 07:52 AM
my Truck has the same stuff about 6 inch wide on the rocker panels, you can't even tell it's there unless your down there looking for it
and yes 3M does make a protectant; whether or not this is a 3M product I don't know
also as Biker listed; those products are great and look good also
BigBlue79 , bikertrash3531 , Booba5185 , Eng89ine , jones03100 , JSoko , Russo2 , sbellinghausen
Door tag codes. Russo2 Garage Talk: Shop Class 101 2 February 28th, 2012 09:54 PM
Replacing Door Speakers 460big_boy 1948-1986 Ford F250 | F350
4 February 28th, 2012 11:03 AM
looking for door panels hammer99507 1948-1986 Ford F250 | F350
4 September 8th, 2011 12:05 PM
Door Locks? steverinaz 2004-2008 Ford F150
7 July 20th, 2011 12:39 AM
door ajar? 975.4 1997-2003 Ford F150
8 July 11th, 2011 11:28 AM
door , sills
