Quantcast 1986 F150 power loss - Ford Truck Club Forum
Old September 30th, 2013, 10:00 AM
timok's Avatar
timok timok is offline
Question 1986 F150 power loss
Can I ask if anyone may be familiar with this problem please? I have a 1986 F150 5.0 with power loss when under a load, seems to run normal until I hook up the boat and trailer, then after less than a mile a total loss of power. Pressing accelerator lighlty will get it moving but barely, pressing a little more and it cuts out altogether. Acts like a loos of fuel pressure. THe engine had been replaced about 50k miles ago, Also on this unit we have replaced EVERYTHING fuel related: rear fuel tank, both sending units with lift pumps, diverter-switch valve, main fuel pump on frame rail. one fuel line. fuel pressure regulator, injectors. Also replaced are TP, MAP, and O2 sensors. Cat. converter also tests ok, runs good until under a load. getting desperate, any ideas?!!
Old October 8th, 2013, 11:13 PM
How heavy is the boat? Which transmission do you have? To me it sounds as if the trans may be getting too hot under load.
Old October 31st, 2013, 12:19 PM
ilovefords31's Avatar
ilovefords31 ilovefords31 is offline
Sounds like a spark related problem to me. The Control Module, or the coil.
86desertride , BigBlue79 , bikertrash3531 , boby123 , Booba5185 , funkman , glc , ilovefords31 , IrishKRO , JamesPaul42 , jhow88 , JSoko , logix89 , Scorekeeper58 , Springdm2020 , stro , timok
stumped and at a loss..help ford f150 chrisandkc 1992-1996 Ford F150
11 November 27th, 2013 01:03 PM
Need help with intermittent engine sputter and loss of power ps4bob 1948-1986 Ford F250 | F350
5 September 26th, 2013 03:07 PM
New member 1986 f150 2wd digger3164 New Member Introductions 2 January 17th, 2013 12:26 AM
1999 f350 powerstroke power loss tcasebeer 1999-2007 Ford F250 | F350
10 July 8th, 2011 09:18 AM
0 February 11th, 2011 07:33 PM
1986 , f150 , loss , power
