Quantcast Trouble with a high millage 5.8 - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-250 | F-350 SERIES | SUPER DUTY > 1992-1997 Ford F250 | F350
Old February 2nd, 2016, 09:21 PM
94wind351's Avatar
94wind351 94wind351 is offline
Default Trouble with a high millage 5.8
I have had my 1994 250 5.8 for 12 years and have never had any trouble with it that I couldn't figure out on my own. It has recently decided not to run real well. It will run great and with no notice start to crawl and eventually stall. I have replaced the plugs, wires, cap, rotor, distributor, ignition control module, ignition coil and fuel filter it runs better now and I haven't had it stall in awhile however I haven't driven very far distance do to a newly found trust issue with my truck it still spudders out a little bit at idle and low RPM any ideas? could the timing be off just enough to cause the rough idle? seems I can turn the distributor enough to either have a good idle in park or neutral or In drive and reverse can't seem to find the medium. Please help.
94wind351 , ASwaff400 , glc , harrison28 , JSoko , pete59edsel , woodworks
slugish/no power/rough idle/bad gas millage judd94 1973-1991 Ford F150
4 January 14th, 2016 10:00 PM
trans trouble geroid 1948-1983 Ford F100
2 May 1st, 2014 08:38 AM
1992 f-150 5.0 trouble sportsman 70 New Member Introductions 4 May 21st, 2013 07:34 PM
Flywheel trouble MIkes 65 Ford 1948-1983 Ford F100
2 May 19th, 2013 09:54 PM
high , many new parts , millage , stall , trouble
