Quantcast Need Help With Trouble Codes - Ford Truck Club Forum
Old January 3rd, 2015, 11:00 PM
MyNameHere's Avatar
MyNameHere MyNameHere is offline
Default Need Help With Trouble Codes
92 f150 302
CEL comes on after about 10 minutes or so and goes away if the engine is restarted.
key on engine off codes:
31 =
EVP – EVP signal is/was out of range – EVP
EVR – EVP signal is/was low – EVR
PFE – PFE signal is/was low – PFE
33 = ALL – EGR did not open/ respond during test or if memory code, did not open intermittently – EVP EVR PFE
Engine running Codes
12 =* Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) – ISC
25 = Knock sensor not tested (ignore if not pinging) – KS
What I know:
EGR pipe is broken between the valve and the intake. I put a high temp hose patch, but I still get the code so I think the valve is bad. Ill be replacing it soon.
IAC valve has had issues for a while. Currently unplugged to keep idle down. Its crazy high when plugged in. I think it may be an intake gasket leak, but dont know how to test that theory. I plan on replacing the intake gaskets when i pull the intake to replave the EGR tube and valve anyway. So if im right that should fix that issue.
And for 25, i hear no pinging, but i haven't got a very trained ear for that sort of thing. How can I be sure ?
All help appreciated.
Old January 5th, 2015, 04:11 PM
MyNameHere's Avatar
This fourm is a let down.
Adsquared , ASwaff400 , cobra1 , Flareside95 , glc , Ken , lostcause , Moore1991bronco , MyNameHere , Palindrome , Russo2 , warodgers
help trouble code 171 & 172 rpez4u New Member Introductions 2 July 16th, 2014 08:37 AM
trans trouble geroid 1948-1983 Ford F100
2 May 1st, 2014 08:38 AM
1992 f-150 5.0 trouble sportsman 70 New Member Introductions 4 May 21st, 2013 07:34 PM
Flywheel trouble MIkes 65 Ford 1948-1983 Ford F100
2 May 19th, 2013 09:54 PM
codes , trouble
or any of their subsidiaries. Fordฎ is a registered trademark of the Ford Motor Company
